Old 01-09-2025, 03:51 PM #1
SMEE's Avatar
SMEE SMEE is offline
SMEE is on a distinguished road
SMEE's Avatar
4WD Will Not Engage
4wd will not engage and I’m getting these dash lights intermittently flashing. Any indication what this could be? A sensor?
2014 Trail with 170k miles
4WD Will Not Engage-img_7037-jpg
'14 Trail Edition
TRD Pro Suspension Swap | Huskys | V1 radar-hard wired | 20% Tint | TRD CAI | Weathertech Vent Visors | 4300k Headlight & Foglight Phillips HID's | Interior LEDs | BFG AT KO 275/70 | Sprint Power Booster Chip |
SMEE is offline   Reply With QuoteReply With Quote
Old 01-09-2025, 05:03 PM #2
4Rums 4Rums is offline
4Rums will become famous soon enough
Search for Neutral Safety Switch (NSS) issues.
4Rums is offline   Reply With QuoteReply With Quote
Old 01-09-2025, 08:32 PM #3
fkheath fkheath is online now
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
The owners manual says you must activate the 4x4 system often to keep it functional. If you don't, it may freeze up.
fkheath is online now   Reply With QuoteReply With Quote
Old 01-13-2025, 05:47 PM #4
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
Use it or lose it.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 08:18 PM #5
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Drive forward slowly and turn the steering wheel a little. Mine is slow to engage at times after not being used for a while.
After it engages, shift it in and out a few times.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 08:59 PM #6
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
When was the last time it worked?
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 11:11 PM #7
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
The green light of the frame and wheels tells you it’s in 4wd. Not sure what the green 4Runner tells you.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 11:43 AM #8
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Most likely a abs sensor, check abs codes. clean them check the wires. Also the wires on the diff.
Old 01-14-2025, 11:46 AM #9
spartacus's Avatar
spartacus's Avatar
For the multi terrain light. Check the wires that go to the front diff actuator.
Old 01-16-2025, 10:40 AM #10
Blackgoat Blackgoat is offline
Blackgoat is on a distinguished road
I use mine at the boat ramp just to keep it working.
My dad has a 2002 Chevy silverado Z71 with 31,000 miles and have never used the 4X4 system.
It has just started throwing the code of service 4X4 ..
The dealership told him its from never using it . I use mine all the time just for that same reason.
Blackgoat is offline   Reply With QuoteReply With Quote
Old 01-17-2025, 12:30 PM #11
mike5 mike5 is offline
mike5 is on a distinguished road
If there's an ABS issue, there should be an ABS or related light on the dash.
2013 T4R TE
My Adventures
mike5 is offline   Reply With QuoteReply With Quote
Old 01-17-2025, 01:09 PM #12
spartacus's Avatar
spartacus's Avatar
Not necessarily, There have been instances where a faulty abs sensor or stretched wire or dirt have caused the 4wheel light to blink.
170k , 4wd , engage , sensor , trail
4 Low won't engage probwhite1 Problems & Warranty Issues 5 01-12-2017 09:07 PM
4L won't engage fasterski 4th Gen T4Rs 8 08-13-2016 09:30 PM
4WD will not engage I think Crazychopstick 3rd gen T4Rs 5 08-03-2015 04:57 PM
Help 4WD won't engage Brett CR 3rd gen T4Rs 3 04-18-2014 09:25 AM
How to engage DAC? AlphaQup 4th Gen T4Rs 13 05-11-2008 11:55 AM
