Old 01-14-2025, 01:25 PM #16
Hig116 Hig116 is offline
Hig116 is on a distinguished road
I do believe this is an oil burning issue for multiple reasons.
1) Smoke has an oil smell
2) Engine is losing oil and has no visible leaks
3) #6 plug has build up. (second photo)
Keith
Engine smoking - Rebuild or Replace-img_8354-jpg  Engine smoking - Rebuild or Replace-img_8355-jpg
Hig116 is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 01:29 PM #17
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Originally Posted by Hig116 View Post
This is certainly an option I have, but trying to save it to my last option. Cost is $5-$6K for a lower mile engine and there is no way to know if it's a good motor. Crap shoot.
I just put in a salvage transmission with 43K miles into our 2014. It cost me $800 for the transmission and they gave me a 6-month warranty, but won’t need that as it runs flawless. My logic in this decision was based on the fact that first service on the transmission is at 60K, so it would be tough to screw it up.
I will admit that an engine is much more complex and the maintenance intervals for things like oil change are shorter, so someone could abuse that. However, the same logic for my transmission still applies, just less so. Sample the oil and spin the engine for a compression test and you would eliminate most concerns. I have seen salvage engines with as little as 2K miles on them. Pretty hard to screw that up.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 02:39 PM #18
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough
thatoneguy's Avatar
Sucks to hear of engine problems. These engines are considered reliable... but they are EXPENSIVE when they go. It's physically a lot of engine.
How many miles are on it? Any ideas what may have caused it? You don't start your January mornings bouncing redline cold, do ya?
2023 TRD Offroad Premium, want to buy 2010+ TRD PRO exhaust, SLC area.
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 02:57 PM #19
The car has about 135,000 miles on it. I question if the motor was under water at some point. I purchased it with the issue from someone who was flipping it, not the previous owner. I have service records in Carfax from the first two owners but not the last owner before the car lot bought it.
Keith
Old 01-14-2025, 04:33 PM #20
Rocko9999 Rocko9999 is offline
Rocko9999 will become famous soon enough
How about doing a motor treatment in addition to the Valv. Restore and Protect. Maybe it's stuck rings and they can be unstuck.
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 04:57 PM #21
Once I do the leak down test and scope, hopefully I will be able to tell if it seems to be a ring issue. If there is not damage to the cylinders, then I'm hoping its a gummed up ring on cylinder 6 and a piston soak might free I up. That's my current best case scenario in my head.
Keith
Old 01-14-2025, 07:25 PM #22
Over on TheTruckStop.us they recommend the following for restoring engines that lose or burn oil:
Amazon.com
Old 01-18-2025, 09:26 PM #23
gwsears gwsears is offline
gwsears is on a distinguished road
Have you checked the oil consumption after 3000 miles or so?
gwsears is offline   Reply With QuoteReply With Quote
Old 01-21-2025, 01:16 PM #24
We just replaced the valve seals last weekend. He drove the car approximately 250 miles and used about 1/2 qt oil. So it's burning a lot more than I expected. Just ordered a PCV valve and plan to do a compression test and leak down test soon.
Keith
Old 01-21-2025, 07:14 PM #25
Keith
Have you scoped the pistons to look for cylinder wall damage? Have any service history on it?
Old 01-22-2025, 11:31 AM #26
I haven't scoped yet, but plan to. As far as history, I have it from the first two owners on Carfax, but nothing from the last owner. The car sat for a while, as I have found several dirt dauber nests. Makes me think it sat long enough for oil ring to get stuck. Maybe.
Keith
Old 01-22-2025, 12:35 PM #27
Keith
If it had even sem-regular oil changes I'd bet the rings are stuck, not worn. I cheap Amazon scope will give you insight. In the meantime, you could pull the plugs, pour in the Berrymans or Seafoam and let it soak for a few days.
Old 01-22-2025, 05:15 PM #28
The car is currently with my son at college, 2 hours away. I'm going to see him in a couple weeks and am going to replace PCV valve while I'm there, since it's simple to do. After that, I won't be able to work on it again until the end of May when the semester ends. Until then, he will keep a check on the oil and really won't put to many miles on it, since he walks on campus.
Once I get it home, I have a scope and will do a leak down test and compression test. I suspect I'll need to do a piston soak to try and free the ring and will be in good shape. Based on the plugs, all looked good except for #6. So, hopefully that is the ONLY cylinder with an issue.
Keith
Old 01-22-2025, 06:44 PM #29
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Keith
Just keep in mind that a leak down test and compression test will not tell you anything about the oil rings, they will only tell you about the compression rings, valves and head gaskets.
2004 Limited V8
Old 01-23-2025, 11:47 AM #30
Good to know. I guess it will help me determine if I have an issue with my compression rings. If I have no leak down issues, that should point to oil rings, I suppose. Thanks for the information.
Keith
issue , motor , pulling , rebuild , replace
Engine smoking somewhere 3G_runner 3rd gen T4Rs 25 03-16-2024 04:44 PM
Repair head gasket, replace engine, or replace truck? backcountrylimo 3rd gen T4Rs 31 10-01-2020 12:45 PM
Valve job or replace / rebuild engine? bam20 3rd gen T4Rs 17 06-08-2016 10:07 PM
Smoking engine and a squeak 4runnernz Classic T4Rs 6 04-30-2014 07:56 AM
Smoking engine 22r s2kpuddydad Classic T4Rs 5 01-02-2012 05:08 PM
