Old 01-18-2025, 09:42 PM #1
sLADe781 sLADe781 is offline
sLADe781 is on a distinguished road
Does power steering fluid absorb water?
I opened a bottle of power steering fluid today to top off my power steering fluid but used so little I still have 99.9% of the container left. Will it still be good 2 years from now or will it go bad after a couple months like brake fluid?
It wasn't sealed like brake fluid so I'm unsure of its longevity.
Not sure if the brand matters but it's OEM Toyota power steering fluid.
Thanks in advance.
sLADe781 is offline   Reply With QuoteReply With Quote
Old 01-18-2025, 10:33 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Thanks in advance.
No, it doesn't.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-18-2025, 11:19 PM #3
Originally Posted by fkheath View Post
No, it doesn't.
No it doesn't absorb water?
Or no it won't be good a couple years from now?
Apologies and thank you for the clarification.
Old 01-19-2025, 08:12 AM #4
tbm837's Avatar
tbm837 tbm837 is offline
Real Name: Tim
tbm837 is on a distinguished road
tbm837's Avatar
Real Name: Tim
both
The '05 has been replaced with a '16, and now with a '23 TRD Sport - Gonna miss the other ones.
tbm837 is offline   Reply With QuoteReply With Quote
Old 01-19-2025, 09:31 PM #5
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Yes, power steering fluid and ATF are both hygroscopic.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 01-26-2025, 12:43 PM #6
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
Thanks in advance.
Well if it's OEM fluid, it is actually ATF.
Will it absorb moisture - yes
Will it still be good 2 years from now - quite likely, yes, as long as it's stored in a reasonably controlled environment like a garage or in your house.
The fluid in your vehicle will absorb moisture much faster as it's constantly heat cycled, and exposed to varying temperatures and weather, humidity, etc.
I just flushed my power steering fluid with a bottle of Dexron synthetic ATF that's been sitting in my garage opened for several years and I have zero concerns about using it. It was in MUCH better condition visually than the brown coffee colored junk it replaced and my system is much quieter after the flush.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
brake , fluid , power , steering , water
Coolant, brake fluid and power steering fluid change and part numbers dcjeeper 5th gen T4Rs 0 03-05-2023 10:24 AM
Whine coming from power steering pump + bubbles in the fluid NOT after fluid change Pyral 3rd gen T4Rs 14 03-19-2022 06:43 PM
Power Steering fluid low Qnbrew88 4th Gen T4Rs 3 07-08-2021 07:25 PM
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
