Ignition Coil Boot & VVT Oil Washer?
Going to be changing the spark plugs and the spark plug tube oil seals are leaking. Trying to order all of the parts OEM but getting frustrated with searching for a few. I've found:
Intake gasket: 17176-31140
Right Valve Cover Gasket: 11213-0P010 (tried to order 11213-51020 but was told that it was the wrong part)
Left Valve Cover Gasket: 11214-31030
Spark Plug Tube Gasket: 11193-70010
Need a couple of parts, having trouble finding them and the local parts guy is giving me the wrong part#s. Can't find them on the forum either:
Rubber boots that go on the bottom of the coil and over the spark plug, just want to replace them as a preventative measure due to age and some having been soaking in engine oil. Dealer parts guy gave me #11193-70010
The copper crush washer that goes on the banjo bolts on the oil lines to the valve covers for the VVT. Dealer parts guy gave me #11193-70010, not what I'm looking for, already had this in my order...
This on my 2011, might be some variation for the later years I'm assuming.
