Old 03-17-2025, 08:15 AM #1
RDN4JC's Avatar
RDN4JC RDN4JC is offline
RDN4JC is on a distinguished road
RDN4JC's Avatar
Getting a "Check Engine" after Changing Plugs
I need some Help.
I have a 2014 4Runner Trail Edition w/KDSS, with 108,000 miles.
I just changed changed the plugs yesterday and now I am getting a "Check Engine" , & a "TRAC OFF", light on continuously, and the green "Multi Terrain" light is flashing.
I had no issues before changing the plugs so I must have done something wrong but not sure what.
I thought I must have missed a wire connection or even a vac. line, when putting everything back together. After double checking all looks good.
Any help would be greatly appreciated.
2014 T4R TE
w/KDSS
RDN4JC is offline   Reply With QuoteReply With Quote
Old 03-17-2025, 09:34 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by RDN4JC View Post
I need some Help.
Get a code reader and find out why the check engine light is on. Many auto parts stores will read the codes for free.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-17-2025, 10:31 AM #3
RDN4JC's Avatar
RDN4JC's Avatar
Thanks, I'll be doing that this evening. I was just hoping that someone would be able to point out something I was over looking.
2014 T4R TE
w/KDSS
Old 03-17-2025, 10:46 AM #4
osugsxr osugsxr is offline
osugsxr is just really nice osugsxr is just really nice osugsxr is just really nice osugsxr is just really nice
would check connections again. What you are describing is probably a loose connection of some sort, I had wires chewed near the fuse box and the same lights you described.
Old 03-18-2025, 11:03 AM #5
BTO's Avatar
BTO BTO is offline
BTO is on a distinguished road
BTO BTO is offline
BTO's Avatar
If you can't find anything disconnected or connected wrong you should try putting the old spark plugs back in.
BTO is offline   Reply With QuoteReply With Quote
Old 03-18-2025, 12:10 PM #6
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
The connections to the back of plugs are weak on the Toyota wiring harness. In particular, the plug to the secondary air valves, particularly on the driver’s side, are susceptible to wires loosening, or even pulling out the back of the plug. This has happened twice to me. I forget the code #. These can be repaired with tools for the plug or simply installing a new pigtail plug.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 03-18-2025, 02:34 PM #7
RDN4JC's Avatar
RDN4JC's Avatar
Thank you! to everyone for trying to help.
I guess this was a false alarm, as after driving to and from work yesterday, every thing is back to normal. Well the warning light are off and the engine is running smoother and with a bit more pep.
2014 T4R TE
w/KDSS
Old 03-22-2025, 09:07 PM #8
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
You should still be able to see stored codes if you’re curious.
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 03-22-2025, 11:46 PM #9
kipmc7 kipmc7 is offline
kipmc7 is on a distinguished road
I just changed the spark plugs on my 2007 4Runner after getting a slight rough idle for a few seconds and then the Check Engine Light (CEL). It is also called the Malfunction Indicator Lamp (MIL). I DO have a code reader and there were 4 codes: Too Rich, Misfire-multiple, Misfire Cly 1 and Misfire Cyl 2. I could not determine when I had last changed the spark plug so I decided to do it myself.
After completing the job, I used the code reader (OBDII) to clear all the codes. They stayed off and there was no CEL. It does take a while for the car to run all the self-tests. That means that when you read the codes you may get some "OK" and some "INC" incomplete. After driving for a few days all tests were OK.
As someone said above, most auto parts stores will read the codes for you, even codes in history after the CEL goes out.
Get yourself a code reader.
Good luck
kipmc7 is offline   Reply With QuoteReply With Quote
changed , changing , check , light , plugs
"Multi-Terrain Select Not Available" + Check Engine Light + TRAC OFF TRDORmike 5th gen T4Rs 32 01-22-2025 09:57 AM
"Check Engine" light keeps coming on with aftermarket upstream O2 sensor. Benski 3rd gen T4Rs 20 12-30-2017 06:08 PM
Cold mornings engine "chugs" and check engine light flashes LoxRunner 3rd gen T4Rs 3 12-26-2016 02:27 PM
check engine light & "VSC off" blinking after installation or Eclipse 6600 hkccool98 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 03-01-2009 12:34 AM
Got the dreaded "check engine" + "VSC off" lights bonedoctor 4th Gen T4Rs 2 11-04-2006 10:33 AM
