Old 11-17-2009, 08:17 PM #1
adkinsadam1's Avatar
adkinsadam1 adkinsadam1 is offline
adkinsadam1 is on a distinguished road
Ground Clearance!
So we all know that the 4th gen. advertised 9.1" of ground clearance but it really only had about 7". Well, the 5th gen. advertises 9.6" inches. Is this for real or have they falsely advertised like the 4th gen? Anyone know or looked at it? Please let me know what any of you think or if any owners could measure the lowest point. Thank you!
adkinsadam1 is offline   Reply With QuoteReply With Quote
Old 11-17-2009, 08:23 PM #2
martini's Avatar
martini martini is offline
martini is on a distinguished road
martini's Avatar
I test drove a limited last night and while I didn't measure it the under body is setup a lot like the 4th gen, there are still some lower spots. As you said if the 4th gen had 7 inches of actual clearance (9.1 advertised), then the 5th gen has about 7.5 inches (9.6 advertised). Didn't get to see a trail edition but I wouldn't expect it to be much different.
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, Dobinsons UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
martini is offline   Reply With QuoteReply With Quote
Old 11-17-2009, 09:47 PM #3
RonMAIDEN's Avatar
RonMAIDEN RonMAIDEN is offline
Super Moderator
RonMAIDEN is on a distinguished road
Super Moderator
RonMAIDEN's Avatar
First we need to know which measuring points are being used on each gen of 4Runner. I know at my rear diff I am over 10" with taller coils and tires.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
RonMAIDEN is offline   Reply With QuoteReply With Quote
Old 11-17-2009, 11:02 PM #4
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
He's talking about the lowest point in center front, roughly under the front diff.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 11-17-2009, 11:29 PM #5
jt_4rnr's Avatar
jt_4rnr jt_4rnr is offline
jt_4rnr is on a distinguished road
jt_4rnr's Avatar
Here you go....The measure was done right underneath the engine skid plate.
One was measure from the plate to the ground (8.5") and the other bypassed the plate (almost 9")
Ground Clearance!-img_0567-jpg  Ground Clearance!-img_0568-jpg  Ground Clearance!-img_0569-jpg
jt_4rnr is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 12:37 AM #6
Thanks a lot! So I guess toyota has equally LIED about the numbers. Here was my 06 limited. 7" when I thought I was getting 9.
Since then that plastic (useless(?)) piece has broken off somewhere off road.
Ground Clearance!-screen-shot-2009-11-17-9-39-35-pm-jpg
Old 11-18-2009, 10:36 AM #7
ssmathis ssmathis is offline
ssmathis is an unknown quantity at this point
Also take into account that the 4th gen used 265/65/17's and the 5th gen uses 265/70/17's. That alone would account for the .5" increase in height claimed and probably the increase in approach and departure angles.
Scott
ssmathis is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 11:14 AM #8
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
JT, i know that you probably told us already somewhere else, but what model did you get?? SR5, Ltd, or Trail??
adkinsadam1, i would not worry about the lip at 7"...i would count where the actual plate is...around 8-8.3"...and this is your actual ground clearance. Lexus website correctly states the GX470's clearance at 8.3"...it is pretty obvious that Toyota lied about the 4th gen 4runner's clearance since Lexus is correct. (Both 4th gen and GX share the same underbody [for the most part, other than the optional KDSS on GX] and tire size.)
So, the new 4runner has about 0.5" (+/-) on the 4th gen due to bigger tires. Like i said before, the 5th gen is really a big makeover rather than a true full redesign from head to toe.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 11:18 AM #9
Thai's Avatar
Thai's Avatar
Both the 4th and 5th gen 4runners' lowest point is not the diff...it is the front skidplate. On your 4runner RonM, your lowest point is the diff because your nose is high (as is your front skidplate). Even on my 2002 4runner (3rd gen), the lowest point was the diff, not the front skidplate. Toyota uses various measuring point underneath to get bogus figures.
2023 Lexus GX
Lets Go Brandon!
Old 11-18-2009, 11:40 AM #10
GatorGreg's Avatar
GatorGreg GatorGreg is offline
Self-Appointed SUV Expert
GatorGreg is on a distinguished road
GatorGreg's Avatar
That's what Mrs. GG told me on our wedding night
2005 Pacific Blue Metallic SR5 4x4
2003 Dorado Gold Pearl GX470 (2003 Four Wheeler & 4x4 of the Year)
2000 Millennium Silver Metallic SR5 4x4 5spd - RIP
GatorGreg is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 03:31 PM #11
benormous benormous is offline
benormous is an unknown quantity at this point
Nice.
2001 SR5 4WD Millennium Silver
OME 882/890
Pioneer DEH-P5000
Hella Micro DE Fog Lights
Profit/Proclip iPhone mount
benormous is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 04:11 PM #12
jt_4rnr's Avatar
jt_4rnr's Avatar
It's the SR5!
Old 11-23-2009, 06:19 PM #13
Thai's Avatar
Thai's Avatar
According to this EDMUNDS preview of the Lexus GX460, the ground clearance is 8.1". (Link: 2010 Lexus GX 460 First Drive) BTW, this is officially less than the GX470 (8.3").
However, the GX comes with 31" tires. Therefore, the Trail Edition (and SR5)with 32" tires should give it a 0.5" increase in ground clearance. So, i believe that the 8.5-8.6" is accurate with the new 4runner.
2023 Lexus GX
Lets Go Brandon!
Old 05-24-2016, 05:31 PM #14
Teephud Teephud is offline
Real Name: Dave
Teephud is on a distinguished road
Real Name: Dave
Stock Ground Clearance
Sorry to resurrect an old thread... I just measured my ground clearance and found it to be only 8-1/2" (under engine skid plate). That's over an inch short of the advertised 9.6"! I'm a new 4Runner owner, and have already bent that skid plate...
Prior to actually measuring this I stopped at the dealer to see if they offered any lift mods. They shooed me away, saying "no, no, the KDSS is way too complicated. You shouldn't do any modifications."
I pretty much went "all in" to get this thing, so don't have much $$ to spend on mods yet. I managed to trade in the stock tires at a local tire shop to get some Cooper AT3s. Still stock size. I figured in a year I'd do some sort of lift. However, I've got a big road trip coming up where I'm going to get some off-roading in, and was hoping to get some sort of low-expense lift. Does anyone know of a good shop in the north SF-Bay area? I'm in Marin.
BTW, I don't mean to gripe. I do love my T4R! I just want it to be a little better...
Teephud is offline   Reply With QuoteReply With Quote
Old 05-24-2016, 06:35 PM #15
TheKent TheKent is offline
TheKent is on a distinguished road
I'm in the East Bay, and I'm getting my lift installed next week at SWAT Customs. People seem to like them and the price was fair. I wouldn't trust a dealer to do it right, or even give you 100% accurate info.
But do realize, the stock 4runner is a very capable machine. I have actually had this conversation with a couple other owners, stock and fully modded. Don't feel like you have to have a lift to go off-road. Know the limitations of your driving ability, and the truck, and you can still get places and have fun without breaking shit.
TheKent is offline   Reply With QuoteReply With Quote
