01-21-2010, 01:35 PM
Shift knob is loose! - Suggestions?
Shifting into R today my shift knob suddenly loosened up! I can turn and tighten it but then it is not 'straight', more at a 45 degree angle. This seems like a pathetic reason to take it back to the dealer. Is there an easy fix for this? Can I unscrew it, tighten the other end then resintall it, hopeing it will line up straight? Well I guess I have the 1st problem with the new 4R, very minor though, but still kind of annoying. Just broke 800 miles, only took about 2 months
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
01-21-2010, 02:36 PM
I think there's a threaded nylon insert inside it. Keep twisting it against the force and it should be able to be rotated to an aligned position. I don't know whether you're just cutting the thread in the insert or if the liner rotates, but it should work.
Chuck
Six 4Runners, Five Generations: http://ckon.zenfolio.com/p185579878
Silver 2018 TRDORP w/ KDSS, tint, hard-wired radar detecter, 285/70-17 Nitto Grapplers, Plasti-Dip, interior LEDs, XenonDepot, Salex, RCI, Sprint Booster, Bilstein, Morimoto fog lights, Subaru Kicker dash tweeters
01-21-2010, 04:20 PM
I backed off the loose item and it was the knob, not the shaft into the console. The shaft was tight into the console and there was no way to adjust anything in the knob itself, so as one members sig says, brute force was applied. I kept tightening & loosening it over and over again, it took about 6 times, each time getting further around with the same amount of force. Now it is back straight, 1 full turn more than from the factory. I guess I will see how long that holds up for.
01-21-2010, 05:30 PM
That's what I meant for you to do - it'll last forever.
Chuck
01-31-2010, 11:24 AM
Loose shift knob fixed.
Mind was loose also. After reading your situation, I gave mind one good hard turn. Done deal.
02-11-2010, 10:06 PM
Excellent tip, thank you! I never would have given it another full turn w/out this advice.
2010 SR5 - Stock for now, factory remote start, leather package
1998 SR5 - traded after a 9 year love affair and 100k miles
