OK, so I have been able to load up Techstream, purchased a compatible cable, and have had the bliss of going through the options and modifying some settings in my '16 Limited 4Runner.
I have confirmed that there is no modifiable setting for allowing the key fob to open all doors with single press of button. Toyota seems to have removed this functionality for some reason. Also, please do not confuse this setting with the ability to TOUCH the door sensor and have it unlock all doors - that's working just fine.
I was also able TO:
- Disable seat belt nag chime
- Remove the "eco" bar from the center LED display
- Enable lowering all power windows and open sliding sun roof for venting by pressing UNLOCK on FOB and holding (does not allow closing via FOB, however using physical key in door cylinder will open/close)
- Change volume of confirmation chirps for lock/unlock
- Change intermittent timing of rear window wiper sweep
There are many other options that I observed, but did not change.
Unfortunately, I could not find:
- Change blinker to auto blink with soft press (pushing but not "clicking" the stick only flashes blinker for as long as held - another removed feature as recent at 2015 in 4Runner)
- Enable FOB to unlock ALL doors with single click of unlock on FOB (as was available until possibly this model year?) Touching handle is separately controlled and available function.
I am using version 12.00.127 with mini-vci J2534 cable purchased from OBDII365.com. I had a newer 12.20.something version of TechStream, but it did not give me the "Customize" button necessary to change these options so I had to remove and reinstall to this earlier version to get the functionality.
Note: If you are planning on setting up a laptop for this purpose, I highly recommend you only use a 32-bit version Windows OS, as the drivers for the cable to not install correctly in the 64-bit OS version and a rather lengthy manual install is required. It's possible, but tedious and not for the casual end user.
If anyone has any recommendations or experiences contrary to what I have posted above, please hit me back on this thread so we can discuss.
Next, I am off to see what I can monkey with on my wife's '17 Highlander with this setup. Shouldn't be much more, I am guessing, since her navigation system allows her much more control over settings natively (as did my Sienna) whereas this my 4Runner give me just about nothing via the navi screen options.
HTH,
Pixel
