Originally Posted by ninja123
Any spacers on the tundra? Rubbing? You think 275/60/20 will rub on stock 1st gen tundra?
I did the math on the wheels, the OEM 20" limited wheels sit out a little further than the OEM 17" wheels, only like 1/2" or so. This allowed me to run a taller and wider tire without rubbing the A-arm.
Depending on your wheel and offset, yes you are most likely going to rub with 275/60-20.
Stock wheels, you are going to rub the upper A-arm, inner fender when turning, and likley the frame.
If you get aftermarket wheels with more offset, you might clear the A-arm and frame but you are going to hit the inner fender and pinch weld worse.
I have run 305/50-20 on my Tundra, with the 20" limited wheels, and there was substantial rubbing on the upper A-arm and substantial rubbing on the mud flap and inner fender, so much so it limited my turning radius.
I then put 275/55-20 on my Tundra, with the 20" limited wheels, and there is no rubbing on the upper A-arm but there is only a business card between the upper A-arm and the tire, and i only rub on the inner fender in off camber full lock turns like hitting a tall lip/curb pulling into a gas station with an incline.
275/55-20 - 31.9 x 10.8
305/50-20 - 32.0 x 12.0
275/60-20 - 33.0 x 10.8
Going to an even larger diameter, is going to push the tire closer to the fender even more when you turn, and closer to the frame when you turn. I would speculate its going to take about a 2.5" lift, new upper A-arms to correct caster, longer sway bar links, no mud flap, and pinch weld mod to clear a 275/60-20 assuming you stay with a narrower OEM style wheel like me. If you go out and get a 20x9" with 0-offset, you are going to be cutting stuff on the fender to keep them from rubbing when you turn.
