01-31-2010, 02:18 AM
Clicking from traction control at slow speeds
I've noticed it in two scenarios, on dry pavement:
A) while stopped on a steep incline, the vehicle will roll back slightly when i release the brake, and the clicking/traction control will turn on when i apply the gas.
B) When backing out of my garage and down my driveway (decline), the clicking/traction control will sometimes get enabled when I accelerate after sliding it into drive. I'm giving it a reasonable amount of time for the gears to shift. I'm not just throwing it into gear and gunning it...
Any thoughts?
SOLD -2010 Blizzard Pearl 4runner Limited 4x4 Toytec Ultimate Lift, Light Racing UCA's, BFG KO 285/70/17
01-31-2010, 09:13 AM
Real Name: Patrick
Real Name: Patrick
Any thoughts?
I think you are describing "Hill Assist".
If your driveway is fairly steep, or your driving on a hill, the "Hill Assist" kicks in. To get a better feel for this does, stop on a hill, take your foot off the brake, and the truck rolls backs 6" or so and stops on its own. It'll hold for about 3 seconds and then beep..alerting you that hill assist is disengaging and you need to either hit the gas or the brake. If you depress the brake it starts all over.
At least that what I think it does....
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
01-31-2010, 09:50 AM
Super Moderator
Super Moderator
I agree with Pat on the Hill Assist point... Backing out of the garage may be it's test cycle. The first time the vehicle achieves 3-4mph after start it does a quick check of the brakes system to include powering each brake. It makes exactly the same noise as a Hill Assist.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
01-31-2010, 12:24 PM
HAC - Read the manual
Any thoughts?
I have noticed the same thing with mine, but only 1st thing in the morning. If I back out of the garage, stop, shift to D, then start to move slowly I get a very MINOR clicking. It does not seem to do it any other time of the day. How loud is yours? Do any lights come on? If you are still rolling backwards and shift the system (HAC) will think you are on an incline and kick in, I found that out once
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
01-31-2010, 03:10 PM
That's exactly what happens. No lights come on. Glad it appears to be normal...
01-31-2010, 09:23 PM
Banned
Banned
our infiniti makes clicking noises also when first driving car. it is the abs brake system doing checks
