2010 Toyota 4Runner SR5 with 2011 OEM Mud guards. They are available in the U.S. now & are listed as a 2011 Toyota accessory. PT769-89110 10-11 Mud/Splash Guards, 4pc. Set $75.00 installed!
For those of you that have the OEM mudguards on a 2011 do they fit with OEM side steps? (I have the crome type)
Is so do the fronts touch the front of the sides steps like the huskys?
Will I need to drill holes?
Do you like them once you have them on?
Do they look good?
Thank you
Mike
Reason: can't type
I poked my head down and looked at the underneath of the running board. The rubber part that is on the front of the RB, i believe u can loose the screw on the back and slide the rubber piece back not the RB.
