05-26-2020, 08:21 AM
#6106
Here’s mine:
Eibach Pro Truck 2.75"/1" Lift
Pro Comp 17x9 -6 offset Vertigo wheels
285/70/17 Wildpeaks
No rub issues
2020 Ford Raptor
2017 TRD-ORP l Eibach Pro Lift l Pro Comp 17x9 l 285/70/17 Wildpeaks l Gobi (Sold)
Reason: Lift Specs
05-26-2020, 01:35 PM
#6107
3” Toytec BOSS lift sitting on 285/70/17 Nitto Ridge Grapplers
Silver 2020 TRD Off Road Premium - 3" Toytec BOSS Aluma Series Suspension- Nitto Ridge Grapplers - Icon Alloys Vector 6 Wheels - CBI Full Skids and Rock Sliders - Rhino Rack Pioneer Platform with Backbone - CVT Rooftop Tent
05-26-2020, 02:10 PM
#6108
Any fender liner/body chop mods needed with this set up? And did you also get UCA?
05-26-2020, 08:47 PM
#6109
Yes, there was a slight cut that they had to do just in front of the front wheels. It was maybe an inch or two cut off the bottom front of the fender. It is almost unnoticeable. I have no rubbing whatsoever. They also installed SPC Adjustable UCAs.
05-27-2020, 06:56 PM
#6110
Originally Posted by Hunter81
Here’s mine with Ironman pro foam 2.
Nice look. What wheels and tire size are you running and do you have any front rear shots? Did you have to do a BMC? Running spacers? Thanks.
05-27-2020, 07:14 PM
#6111
Originally Posted by AlblineStar808
2.5/2 cornfed 1" Toytec BL Camburg UCAs 285/70 & Spidertraxx
[IMG] [/IMG]
Great lift height. What size Spidertraxx and any issues rubbing?
05-28-2020, 09:08 AM
#6112
Originally Posted by EL3V8TE
Lift specs?
05-29-2020, 10:35 PM
#6113
Hey guys I just installed a 1.5”/2” Cornfeed spacer lift on my 2020 Pro with 285/70 Toyo Open Country M/T tires. They rub on the mud flaps when turning. I was not expecting that. Is this normal?
05-29-2020, 10:48 PM
#6114
Can you attach pics from phone?
It says Error when I try.
05-30-2020, 10:29 AM
#6115
Originally Posted by TRDHULK
OEM Fox shocks/struts/springs
Burtman 2.5/2" spacer lift
Spidertrax 1.25" wheel spacers
Yokohama 285/75r17 Geolandar G003 MT's
I like the tires! Were the wheel spacers required to prevent rubbing with the UCAs or just for looks? Stock or aftermarket UCAs? How do you like the Geolandar MTs? I’m thinking of going the 255 route for lighter weight.
2019 TRD OR, Silver, Lasfit LED low beams, RCI skid plate, RAV4 mirrors w/blind spots, Ventvisors, Pedal Commander
05-31-2020, 12:29 AM
#6116
Thank you! I installed the spacers the day after I bought the truck and did tires weeks later; I just like the looks with the spacers. I have stock UCA’s. I love the tires and would buy them again.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
05-31-2020, 12:31 AM
#6117
Originally Posted by 1100 Remington Man
How has this lift worked out for ride and performance ?
Not bad. A little more firm than stock but I love it
05-31-2020, 10:29 PM
#6118
Real Name: Chris
Real Name: Chris
Lots of things cause tire rub. Wheels, poor alignment, not all tires are created equally. Remove the mud flaps, simple solution.
06-01-2020, 01:34 PM
#6119
Doesn't seem too out of the ordinary, those tires run big.
06-01-2020, 03:24 PM
#6120
I did remove the front ones and no more rubbing.
Thanks.
Is there a mud flap delete plate?
When I removed the rears it leave a large open hole.
