05-26-2010, 11:28 AM
Alignment Specs?
Anyone have them? Are they the same as 4th Gen?
Had alignment done with new tires and sheet says 2003-2009 4Runner.
Thanks
2003.5 4Runner Sport, V8, Galactic Gray, Cornfed 1" front & 3/4" rear, Bilstein 5100's, FJ Cruiser wheels, 265/70/17 Firestone AT's
2010 4Runner Trail, Magnetic Grey, PIAA horns, FJ TT coils/shocks, Daystar front pre-load spacers, 265/70/17 Firestone AT's
05-26-2010, 12:57 PM
Real Name: Marshall
Real Name: Marshall
TIS FSM for 2010 4Runner is here...
Those specs and a whole lot more... it's under the "ALIGNMENT / HANDLING DIAGNOSIS: FRONT WHEEL ALIGNMENT: ADJUSTMENT (2010 4Runner)" section of the repair manual.
I think my thread needs to be stickied...
Current cars: 2010 4Runner Shoreline Blue Limited 4X4 3rd row & Nav, 1994 RX7, 1978 F-150 4-WD (this is the work/mud ridin truck-needs some work though)
Cars owned: 1994 Integra, 1988 RX7 TII, 1987 RX7 base, 1990 RX7 GTU, 1985 Ford LTD (first car-biggest piece of crap). FSM+EWD here
05-26-2010, 01:47 PM
Thanks, which of the 6 RM zip files do I need? I tried RM.zip but I am getting an error when I try to extract (download worked).
Can you cut and paste the alignment specs here?
Thank you
05-26-2010, 02:32 PM
Real Name: Marshall
Real Name: Marshall
you need to download all three rm files and then unzip. there are two rm versions pdf and non pdf.
05-26-2010, 02:35 PM
I tried all 3 non-pdf RM files and got an error when extracting (in part 2, I believe). Then I tried all 3 pdf RM files and get an error on the main file RM pdfed.zip.
05-26-2010, 02:37 PM
Real Name: Marshall
Real Name: Marshall
what program are you using to extract the files?
05-26-2010, 02:39 PM
WinZip Pro 11.2
05-26-2010, 02:40 PM
if you have the alignment specs handy, i'd appreciate it. need to head to tire shop very soon.
thanks
05-26-2010, 02:58 PM
Real Name: Marshall
Real Name: Marshall
this is the quickest way I can do it from work...see attached
05-27-2010, 03:34 PM
Thank you nashman
05-27-2010, 07:38 PM
Real Name: Marshall
Real Name: Marshall
no prob!!
