Old 09-03-2010, 12:29 PM #31
Tbob32 Tbob32 is offline
Tbob32 is on a distinguished road
Originally Posted by Riser View Post
So to confirm, no manufacturer of sliders make a pair that can install on SR5/limiteds without removing/modifying the rocker panels?
If you can order a set that come straight out from the frame mount as opposed to angling up, would you still have to remove or modify the SR5/LMTD rocker panel covers?
Tbob32 is offline   Reply With QuoteReply With Quote
Old 09-06-2010, 04:04 PM #32
Okki Okki is offline
Okki will become famous soon enough
Shrockworks on 2010 Limited
I installed the Shrockworks Rock Rails on my limited and ran into a few issues. I had to bend out the hard lines in the front and create a bracket out of a bolt, 2 nylon spacers and a hose-guide with rubber padding.
I also spent 2 weekends cutting the factory rocker panels and used the trimmings to clean up the rockers so it would have a more factory look when reinstalled.
The end result was that there was too much material (especially at the front wheel well) hanging to low and as a result when the truck moves, you would hear the plastic moving. I am now shopping around for the Trail Edition plastic (rockers, fender over molding and mud guard) and my dealer is painting it to match the factory black of my truck.
Okki
(I have more pics of the process, but since I think the experiment failed, I didn't include them here but can make them available on request.)
Rock sliders / Rock rails-img_2426-jpg  Rock sliders / Rock rails-img_2430-jpg
Okki is offline   Reply With QuoteReply With Quote
Old 09-06-2010, 05:12 PM #33
kenjan1970 kenjan1970 is offline
kenjan1970 is on a distinguished road
I would be interested in knowing if it is possible to make sliders that do not require the removal of that trim pannel or if a rocker trim could be included in a package with sliders, these guys work in metal, maybe someone does fiber glass, black in color would be fine for the limited or sr5 Any Ideas?
kenjan1970 is offline   Reply With QuoteReply With Quote
Old 09-06-2010, 09:10 PM #34
SeattleMike's Avatar
SeattleMike SeattleMike is offline
SeattleMike is on a distinguished road
Okki
I commend your bravery. It looks painful from just the two pics you have posted.
2010 Trail Edition 4Runner - KDSS / Nav / RRO Sliders / Perkins Rack / Java Drawers / Duratracs 265/70/17/E
SeattleMike is offline   Reply With QuoteReply With Quote
Old 09-06-2010, 09:23 PM #35
Been there done that... My 2002 CRV had a custom made vented carbon fiber hood..S2000 start button and RSX Type S Recaro seats. So this one has been easy so far Harper7 is my role model with this vehicle.. I just found out about his new skid plates.... I'm jealous
I was fully aware and okay with the fact that I might destroy the rockers, but since Harper7 had already told me that I could go the route of TE fender over-molding and rockers, it was an educate gamble. Hoping to find out all the part numbers for the TE plastic tomorrow and start shopping for those. sucks in that it will be another $600 but I guess that's the price for keeping that "stock" look. I'll post the part numbers when I have them all.
I posted a couple more pics here:
Shrockworks Sliders on Limited
Okki
Old 09-06-2010, 09:34 PM #36
On a Limited or SR5 you would lose so much ground clearance, it would not make sense to make sliders that would fit below the stock rocker panels. If a custom shop would have to engineer and produce the plastic pieces you would likely end up paying more that simply buyig the Trail Edition rocker panels, front fender over-molding and mudguard and having those painted in your truck's body color. That's the route I'm going now.
Okki
Old 09-06-2010, 10:03 PM #37
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
Okki
Okki , I did a write-up with part numbers on it here. http://www.toyota-4runner.org/5th-ge...tml#post603760
I'm not sure how it's going to work out just replacing just part of it on the sides.
The back may be a problem as the flare over the rear wheel well for the TE is thicker near the back where it ties into the rear bumper flare. Also,the rear bumper flare on the TE is a separate part and has the top part of the mudflap molded in. Where it is molded into the bumper cover on the SR5/Limited and not separate.
On the front wheel flares and mudflap,it looks like it will tie into the front bumper cover except the fact the TE's are sort of a pebbeled texture and not smooth like the SR5/Limited. A good body man should be able to fill smooth and paint that to match but he'll charge extra.
The best thing to do is find a TE in your area and park next to it and see the differences.That is what gave me my mental blueprint!
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 10-08-2010, 02:28 PM #38
Will733's Avatar
Will733 Will733 is offline
Will733 is on a distinguished road
Will733's Avatar
Anyone try the weld on sliders yet? For some reason they are less expensive ($400 installed at a local shop).
Maybe the bolt-ons ordered online are better material, but I've heard nothing but good reviews from Tacoma drivers with weld-on sliders from this shop.
Just not sure if it's worth $580 after shipping for the Shrockworks compared to the $400 weld-ons, unless it voids warranty's or has any other potential issues.
2010 MAGNETIC GRAY 4X4 SR5
Bilstein 5100's at 1.75" | Rear Driver Side Daystar 1.5" Spacer | 285/70/17 Duratracs | Spidertrax 1.25" Spacers | FJ Wheels | FJ Shift Knob | TE Grille
De-badged | Plasti Dipped Chrome | Pilot Stub Antenna | Shrockworks Sliders | Window Tint | Interior LED's | Air Dam Removed | Side Skirts Removed
Will733 is offline   Reply With QuoteReply With Quote
Old 10-13-2010, 11:00 PM #39
rlinger's Avatar
rlinger rlinger is offline
rlinger is on a distinguished road
rlinger's Avatar
Ordered my Shockworks last week. ETA of November 15th for delivery.
Hopefully they arrive sooner than later!
Originally Posted by harper7 View Post
Here is a pic of the measurement for exactly how far the Shrockworks stick out .This picture is shot looking straight down near the rear of drivers doorway,right below where the door weight/info stickers are.
It gets a little bigger,maybe a 1/4 to a 1/2 inch,the farther you go back as the sliders go straight like the frame but the body curves in a little bit near the rear doors.
If Egstyle or someone who bought the Rocky road ones,would be so kind to shoot us a pic of the measurement of rocky road sliders at the same place we would know how much farther out they sit. I really don't think it's that much.
rlinger is offline   Reply With QuoteReply With Quote
Old 10-14-2010, 09:19 AM #40
BrianLSU's Avatar
BrianLSU BrianLSU is offline
BrianLSU is on a distinguished road
BrianLSU's Avatar
Okki,
Have you tried doing the TE trim runners above the sliders yet? Does it fit against the LE front and rear trim?
Thanks.
2010 Limited 4x4
Cooper Zeon's, Baja Rack, JL Audio speakers
BrianLSU is offline   Reply With QuoteReply With Quote
Old 10-14-2010, 10:02 AM #41
Originally Posted by BrianLSU View Post
Okki,
Thanks.
@BrianLSU
The rear is fine, but on the front you need to also replace the fender over-molding and the mud guards. I got mine back from paint (I would NOT try this at home.. it cost me $40 more to fix my created mess before they could properly paint the parts - $390 total paint bill) early this week and they are going on this weekend. I'll post pics of the process afterwards.
The plan is to wash and wax the truck saturday and than install the parts (can't was the painted pieces for 30 days).
Okki
Old 10-14-2010, 11:11 AM #42
BrianLSU's Avatar
BrianLSU's Avatar
Ok, so the rear doesn't require a swap.
Now, the fender over-molding, do you mean the actual exterior fender flares? I suspect so since you needed to get them painted, I guess to match the painted rear.
What was the total cost, materials and paint?
Thanks.
2010 Limited 4x4
Old 10-14-2010, 02:21 PM #43
Hi Brian,
Search for posts by me, I have a lengthier write up on the whole process that includes part numbers and prices, but the short answer:
Rock Rails $640
Replacement TE parts $680
Professional paint job $350
It's a pricey project
Old 10-14-2010, 08:07 PM #44
BFLAN BFLAN is offline
BFLAN is on a distinguished road
Hi Brian,
Rock Rails $640
Or just have some sliders built that fit your SR5 or Limited!!!!
Any shop can build these sliders in your area. I built mine, and hundreds of people used to build these themselves before they were bolt on accessories.
My advice is take some pictures of what you want down to your local 4X4 or fabrication shop. It will take them a couple days and cost you the same or less as Shockworks!!!
BFLAN is offline   Reply With QuoteReply With Quote
Old 10-14-2010, 08:59 PM #45
snow&surf's Avatar
snow&surf snow&surf is offline
snow&surf is on a distinguished road
snow&surf's Avatar
This! Jason Demello made my sliders. I kept my LE rocker panels and he trimmed them down to about 1.5" - 2" total height. I keep the finished look and didn't need to buy extra parts, the only thing I did was black the chrome accents on the panels. I didn't even install them myself and the total cost was less than the price for the SW sliders.
2010 Limited 4x4 - Magnetic Metallic Gray - loaded
Mods: ICON Stage II Suspension / 295/65R18 Duratracs on Gauntlets / Demello Sliders / CBI Rear Tire Carrier / Lightwerkz RX330-TSXr projector retrofit / Shrockworks Bumper / Magnaflow 12586 / aFe 31-10208 / Rear Diff Breather mod / BMC / Debadged & Chrome Blackout / Fiamm El Grandes / Infinity Kappa 32.9cf / 5" Mangowalk / 18% tint / Weathertech Liners / Yakima FatCat6 / Thule Hang Two Surf Rack
snow&surf is offline   Reply With QuoteReply With Quote
