07-22-2010, 08:14 PM
Light racing or total chaos UCAs
finally, after reading the different options (thanks to everyone) and my needs i've decided to go with toytech lift kit, but undecided about UCAs and also if its worth it to buy lower rear control arms
07-22-2010, 10:20 PM
Just an fyi, you do not need UCAs with the ultimate. Nice to have yes, required no.
2010 4Runner SR5 Magnetic Gray
07-22-2010, 11:43 PM
thanks i thought so, but i do want to change them just do not know the difference or advantages between one and the other.
2010 TE 4R, shockworks rock sliders, husky liners, king shocks, Total Chaos UCA's, icon 2" lift rear coil springs, toyo open country at 285/70/17, Gobi Rack, Vision X 32', Icom radio, budbuild skid plate soon shockworks front bumper....
07-23-2010, 12:10 AM
Real Name: Will
Real Name: Will
total chaos is uniball, a lot better then the light racing ball joint. uca's are not required with a lift although they help increase the amount of front travel and help keep it aligned to factory specs. anything over stock will be an upgrade since you are goin with toytec ultimate with the new coilovers. uni balls are known to squeek however all you gotta do is grease them. im def. not an expert as im about to purchase my first set. hopefully someone who has had them will chime in
2005 Tundra DC TRD 4x4
Couple New Chevy’s---Sold
1997 LTD 4x4---Sold 7/1/15
2003 Tundra 4x4---Sold 6/24/14
2003 4Runner---Sold 3/23/11
07-23-2010, 02:37 AM
Real Name: Gary
Real Name: Gary
Originally Posted by 4Runner8
total chaos is uniball, a lot better then the light racing ball joint. hopefully someone who has had them will chime in
Not sure where you get the info that TC is way better the LR's.
They both give the same amount of travel and they both do what they supposed to do.I've had both. TC's do look way cooler. Just wish they would seal that uniball like Icon did.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
. ...........Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
07-23-2010, 10:22 AM
Real Name: Will
Real Name: Will
well uni ball's are supposed to be better then ball joints, and yes they look way better but are almost 700, if i was about to spend 700 i would just go ahead and fork over 1100 for icons
07-23-2010, 01:28 PM
and in your opinion the icons are way better than anything out there
07-23-2010, 02:23 PM
You can get LR's for around $400, I am sure they work just as well, and you don't have to monthly grease them to keep from squeaking. Compared to 700 for TC's or Camburg's, or 1200 for Icon's, it was a no-brainer for me. I just put mine on, and should hopefully be able to hit some local trails here later in the weekend, so I'll let you know if they have any problems.
07-23-2010, 02:52 PM
5th Gen Moderator
5th Gen Moderator
TC is the best Harper and you know it. I don't see Light Racing posting up pics of bad a$$ 5ths on their site
Scroll to the bottom of the page VV
Total Chaos Upper Control Arm Suspension System for 05+ Toyota Tacoma, 07+ FJ Cruiser & 03+ 4Runner
Originally Posted by 7harper
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
01-05-2011, 02:27 PM
I ordered a set of light racing UCA's today. After my lift (toytec ultimate lift kit) the dealership was having issues getting it aligned to the specs Toytec suggests with the stock UCA's. I avoided ordering them because I wanted to see how it rode before replacing them. I think the OEM UCA's rub on the coils when i hit speed bumps. Hopefully both of these issues get resolved when the new UCA's get installed.
SOLD -2010 Blizzard Pearl 4runner Limited 4x4 Toytec Ultimate Lift, Light Racing UCA's, BFG KO 285/70/17
