Thread Tools Rating: Thread Rating: 262 votes, 2.55 average. Display Modes
Old 05-06-2022, 02:31 PM #541
Farbjorn Farbjorn is offline
Farbjorn is on a distinguished road
Hi, I'm new to this forum just having purchased a 2012 4Runner SR5. I got the 4R because my old towing vehicle (1998 Sienna) was just not up to towing my trailer. I've got a vintage Aladdin trailer with a weight of about 1700 lbs. The width of the trailer is 7' and 15' long. I found on this site that the actual width of a 4R with mirrors is 84" which is the width of the trailer. My question is: How do I properly adjust the add-on mirrors, all of my previous towing experience has been with trailers I could see over. Thanks!
Farbjorn is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 11:12 AM #542
ThunderMtn ThunderMtn is offline
ThunderMtn is on a distinguished road
OEM ratings are massively conservative to begin with. No reason to further reduce it.
ThunderMtn is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 04:36 PM #543
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I don't think there are any mirrors that fit the 4Runner that are either snap on extenders or slide out extenders like you can find for almost every other truck and many SUVs. The best I've found is the cheap Amazon clip on set. They're kid of a pain to get adjusted well and they don't hold their adjustment very well so you have to re-aim when you put them on every time. But... they actually worked really well for me. They held tight to the mirrors and didn't slip or fall off. They gave really good view down the sides of the camper. And they're dirt cheap. They're $9 each right now. They come individually - so you have to order two. But for under $20, you can't beat them for towing wider trailers.
Amazon.com: CIPA 11950 Clip-On Towing Mirror Black & Silver, 15.75 Inch : Automotive
Old 05-08-2022, 10:01 AM #544
4Reak Show's Avatar
4Reak Show's Avatar
Towing experiences with your 5th Generation
2016 4Runner:
B&M trans cooler
RedArc brake controller
Firestone Airbags @ 10-15 psi
Amazon clip on tow mirrors
2021 Coleman Lantern LT17B:
3000 lb dry/3850 lb max/
BlueOx sway pro 750 WD hitch
Keep 4Runner in S4, 65 mph and it’s fine. Not breaking any records but it does the job. Myself (185 lbs) wife (120 lbs) 2 and 5 year old, plus ice chest with 50 cans in the back. Manual S4 mode is also nice to easily and quickly pop it down to 3 to pull a hill. Get the RPMs up. I’ve hit the trans lines and trans pan with a heat gun after some good hills and the temps there are like 150-180 only. I attribute the low temps to S4 more so than the added cooler. D (5th gear) hunts on and off with torque converter waaaay too much.
Edit: I think the picture is prior to airbag install so the back end is a touch lower than current
Old 05-20-2022, 11:51 PM #545
10KftinColorado 10KftinColorado is offline
10KftinColorado is on a distinguished road
Mpg
After 1000 miles towing the Aliner camper @2500 pounds with 2022 OffRoad I'm consistently getting 18 mpg on Colorado mountain highways, better than expected. The 4Runner LOVES premium fuel, makes a real difference. Overall cost may come out the same but the extended range is a plus with the trailer.
10KftinColorado is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 12:56 AM #546
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Originally Posted by Ascole View Post
My teardrop is 2k+ lbs and pulling grades over 4% for extended periods of time in warmer weather will heat my transmission up to 245 degrees and sometimes higher. I’ll be adding a transmission cooler before the summer months hit
A scan gauge or some other way of monitoring trans temp is very helpful when towing in the mountains.
Some people with GM trucks are altogether deleting their trans T stats. Could we benefit from the same?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 09:54 AM #547
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
I’ve towed my Porsche from ny to Boston
Towing experiences with your 5th Generation-b613a3c9-9b7f-4b08-9889-ae7357866da8-jpeg
Mudballz is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 11:21 AM #548
RockyMtnT4R RockyMtnT4R is offline
RockyMtnT4R is on a distinguished road
We're running a similar set up (Aliner Ranger 12, 1775 lbs empty) and get about 16-ish mpg on mid-grade... It doesn't help that I'm running 275s, but I guess I'll have to give premium a try next weekend on our way to the flat tops.
RockyMtnT4R is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 12:31 PM #549
Aside from controlling the highest allowed gear, does using S (as opposed to D) change shift points?
Old 05-21-2022, 09:13 PM #550
I've compared mid-grade vs premium several times both with and without trailer and finding that premium consistently improves 4Runner fuel economy by 10%.
Old 05-23-2022, 12:23 PM #551
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
used to tow the sleds out west - does great until i start to hit inclines.
Only thing i really "tow" is the motorcycle carrier as seen below. I got the firestone bags in the rear to help with the sag.
Does great other than just knowing to give myself a little extra braking room with the extra weight (estimated 300ish lbs more)...
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 02:55 PM #552
Any recent accounts of someone with a late 5th Gen 4Runner towing right up to the limit (4500-5000 pounds) and outcomes?
Old 08-26-2022, 07:59 PM #553
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
I've worked at a marina for 30 years and I tow up to 47' boats on a regular basis - not with my T4R if course. For my own towing, I had F-150's for years but got tired of stuff breaking. So, in 2014 I bought a Tacoma TRD Sport 4x4 which comes with the towing package. It did a reasonable job of towing my boat, so when it came time for something new, I stayed in the family and bought a 2021 SR5 Premium.
To say that the T4R tows the exact same boat better than the Tacoma would be an understatement. It's more comfortable, turns tighter, gets better mileage and generally just feels much more comfortable with the boat behind it.
What am I towing? I have a 1992 Progression 22 with a new four stroke (4.6 liter) Mercury Racing 250R on the transom. The trailer is a 1992 EZ Loader single axle with surge brakes. Although I've never weighed the whole thing, based on published weights for the boat and motor, I'd guess the whole thing comes in somewhere between 3,500 and 4,000 pounds.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 08-27-2022, 04:14 PM #554
buffalojay's Avatar
buffalojay buffalojay is offline
Real Name: Jacob
buffalojay is on a distinguished road
buffalojay's Avatar
Real Name: Jacob
How are you liking your A-Liner me and my wife just saw these the last time we went tent camping and now are actively looking for one. We are thinking of doing their biggest one just cuz we theres 4 of us. Any tips on them would be much appreciated.
buffalojay is offline   Reply With QuoteReply With Quote
Old 11-21-2022, 08:25 PM #555
Dzldust Dzldust is offline
Dzldust is on a distinguished road
Huh?
Dzldust is offline   Reply With QuoteReply With Quote
2010 limited , 4wd , blizzard pearl , towing
