05-31-2018, 11:44 AM
Rear Bilstein 5100 - Correct Upper Bushing and Washer Arrangement
Just did my 5100 @.85" install on Monday, but ran into an issue figuring out the correct rear shock upper bushing arrangement. I ran numerous searches on this an various other forums, with no truly definitive answer. I ended up installing them like this, since it was a holiday and I needed to get my 4Runner back on the ground:
Now that I've had a talk with Bilstein, the one rep I spoke with said that the washers should actually be flipped opposite of the above so that they are not cupping the bushing. He said this allows more articulation of the shock shaft and will prevent the shaft from breaking.
How did you guys do yours? Of those who did it like the above image, have you had any issues? Just wondering if I should go through the trouble of pulling the dang things off and re-installing.
Other than that, the install went perfectly using the "no spring compressor" method, and I think my alignment came out pretty good too.
Thanks for the help!
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
05-31-2018, 03:24 PM
I inverted mine per the instructions...I didn’t know the reasoning, but it makes sense from what you mentioned. Mine are 5160s, but assume the same install.
2023 SR5 Hefty FabWorks Slider, Falken AT4W
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
05-31-2018, 03:42 PM
Yeah it would've been nice if Bilstein included instructions with the 5100 rears. Now that I'm looking at it, I see they show that detail in the 5160 instructions.
I can't be the only one who's made this mistake, haha...
2018 TRD ORP - Sold
05-31-2018, 04:43 PM
Real Name: Christoph
Doh!
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
06-01-2018, 12:13 AM
Looks like the spam bot has taken a real liking to my thread, haha.
Thanks for the input guys! Anyone else remember how you set your washers up?
2018 TRD ORP - Sold
06-01-2018, 10:45 AM
Real Name: Mark
Real Name: Mark
For my 5100s, I just went by how the Toyota washers were installed, the Bilstein stock photos/other instructions. So my washers are "cupped". But so have they been every shock absorber on every vehicle I have replaced shocks on. I'm not going to worry about it.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
06-01-2018, 11:20 AM
Thanks for the reply! That makes sense, and is also one of the reasons I cupped my washers too.
I think I'll probably just leave them be then. I don't think I recall seeing many 5100 shaft failures on here anyway (although I found record of a few, but it seems with lifted rear and heavy duty off-road use).
2018 TRD ORP - Sold
06-02-2018, 11:52 AM
I had the same question when I did the rear shocks. Posed the question to “Bilstein” and got the same answer you did: the washers should dish away from the rubber, not cup it. Maybe I spoke to the same “Bilstein” guy a year ago. Although I did the install per his instruction, I am still a bit dubious. A week ago, I went to the trouble of taking the top washer and bushing off for a looksie. Everything was well seated and centered. The shock threaded rod was not rubbing against the mount. I left everything as is, at least for now.
06-02-2018, 04:51 PM
Real Name: Mark
Real Name: Mark
They should've just made them flat and a bit smaller in diameter. Then no one could put them on "backwards", whatever that may be, and they could've saved some money.
06-02-2018, 06:25 PM
I’ve put my share of bushings together, there’s no way they want them like that.
Edit: they want them like that.
09-21-2023, 11:10 AM
Sorry to necro this thread, but it seems that the consensus is to have the cupping edge pointed inward, regardless of what Bilstein said. I agree that flat washers would have been a better option, considering that they welded a nut to the shaft of the rear shock for tightening and removal. I tried it the way Bilstein said and if I were to put it on that way I would not be able to access the welded nut after installation. I guess if it's a dedicated off roader it would matter more, but where my rig is 90% on the highway until my 3rd gen gives up, it doesn't hurt to install them the same as the factory Toyota bushings. I do have some QC concerns, as there was some spackling on my threads for the shock which wouldn't allow the smaller washer to slide onto the shaft. Not a deal breaker, but I wouldn't expect that from Bilstein.
Huerta
"Black Burro" 2000 4Runner SR5, e-locker, Tundra/906 lift, Tundra brakes, 348K
"Fez Johnson (FJ)" 1997 Land Cruiser 40th Anniversary, Antique Sage, triple locked, 195K SOLD
"4-Lo Silver" 2010 4Runner Trail, bone stock, 178K, Lovin' it
09-21-2023, 01:20 PM
The instructions were included in each Bilstein box and although I didn't like that method, I followed them. The cups face outward.
Every other shock of that style I've ever installed in my life has been been with the cups facing inward. I'm surprised I even looked at the instructions anyway.
09-21-2023, 02:59 PM
09-21-2023, 08:15 PM
One of my 5100 rear shocks has already blown at less than 50k miles. Would be nice if this new configuration will make these last longer. Not holding my breath.
10-06-2023, 08:27 PM
I replaced my leaky rear Bilstein with a new one this week. I followed the new (2020) instructions.
Here are a couple tips:
Use a 22mm thin wrench to hold the shock body.
The new configuration of the washers makes it hard, or impossible, to get a normal wrench in there.
You can get a useable 22mm thin wrench on Amazon for less than $10.
The new Bilstein nylock nut is an 18mm, not 19mm.
But…a 19mm wrench will work.
I got a ratcheting 18mm on Amazon for about $15. Any excuse to buy new tools.
My lower bolts were rusty but finding the correct and available part number to replace them is proving surprisingly difficult.
I just cleaned mine up and hit them with rust reformer.
