Thread Tools Rating: Thread Rating: 262 votes, 2.55 average. Display Modes
Old 10-07-2018, 03:52 PM #481
TEN613RPro TEN613RPro is offline
Location: N California (not the middle called northern)
TEN613RPro is on a distinguished road
Originally Posted by WVhillbilly View Post
I though an Excursion had F250 springs under it.
Most of the time when I see one these days it's dragging a 30ft bumper pull camper behind it.
The OEM springs are far from f250, everything else under there is though. OEM is called family package for a reason. Set up right they are great tow'ers.
2018 TRDP Cavalry Blue
TEN613RPro is offline   Reply With QuoteReply With Quote
Old 10-07-2018, 11:16 PM #482
ShooterF16 ShooterF16 is offline
ShooterF16 is on a distinguished road
Hi, All. Been a little while since I posted here but thought I’d add my info. I’ve towed my 23’ travel trailer about 20k miles since I’ve had my T4R. For reference, the trailer is about 3200lbs dry and 3600 full of everything. Like everyone else, I highly recommend airbags and a WDH. I use both.
My contribution to this thread is that I also installed 4.56 gears. Since the gear swap, towing is definitely better. However, you will definitely notice the higher rpm and loss of mpg. It’s been just over a year since I’ve had the gears installed and I lose about 1.5mpg during the summer and closer to 2-2.5mpg in the winter. I have a theory that in addition to the crap winter fuel, the recommend viscosity gear oil hurts, because I notice a difference with change in outside temps (same drive and season). This is all while NOT towing.
Anyhoo, during towing, my mileage is about the same. You can’t really tow any faster, or expect that you’re going to be able to use 5th gear (although you can a little bit), but everything is a lot nicer. It’s a Toyota, so it’s happy to rev a little bit higher all the time. There is a noticeable improvement to acceleration and just getting out of your own way. Sorry, I did not take before and after 0-60 times.
My final version of the T4R is to get 34x10.5 tires (maybe the 285/70 load C) before my truck succumbs to the salt here in Syracuse. With that combo, the calculators would give me a 7% increase in mechanical ratio, vs the 15% I have now with stock size tires. Im running load E tires and the decrease in weight and taller tires may actually push me back towards “normal”mpg. And I’d still have better towing.
Would I do gears again? Yes, just sooner. If you’re contemplating a lift or bigger tires and you tow, it should be very high on your list.
Cheers,
Nate
Nate
2012 SR5, Airlift 1000, Level 8 Guardian, BFG T/A KOs, aux trans cooler, Bilstein 5100
ShooterF16 is offline   Reply With QuoteReply With Quote
Old 10-07-2018, 11:55 PM #483
Off2Mtns Off2Mtns is offline
Off2Mtns is on a distinguished road
@ShooterF16 , thanks for the insightful post. I've contemplated a regear myself, but man, don't know that I could stomach a 10-15% hit on the gas mileage... that's rough! It sucks bad enough as it is, 15-16 mpg since we drove it off the lot.
Off2Mtns is offline   Reply With QuoteReply With Quote
Old 10-08-2018, 08:18 AM #484
Mines got just over 110k miles and is well broken in. On a normal tank I get 17.0mpg, which includes about a 50/50 mix of city and highway. I can still get 19mpg on the freeway if I set the cruise on 60-65. MPG get way worse once I start going 70 and above. Since most of my highway miles are commuting, I’m going 70-ish to keep up with traffic and avoid road-ragers.
I’d expect your mpg to get better if you’re still breaking it in and it’s on stock tires and lift
Nate
Old 10-09-2018, 08:56 AM #485
bbaxter51's Avatar
bbaxter51 bbaxter51 is offline
bbaxter51 is on a distinguished road
bbaxter51's Avatar
I just got back from towing my buggy 8hrs with my T4R and was really skeptical about it. I put a brake controller in and loaded it up! It towed ok, better than expected. I had to stop about 2 hrs in and pull the buggy back about a foot to lessen some tongue weight and that helped a lot. Trailer is a 18' 7k lb Trail-Load that weights ~1800lbs empty; buggy weights 3220, trail ready. I'm sure with tools, loaded with camping gear I was over the 5k rating, but it did really well all things considered. It's mostly flat here in MN so I just took my time and made sure the trailer brakes were dialed in. I'd do it again without hesitation.
2.5" leveling kit in the front with 285/75/17 KO2's load E.
I just realized I didn't take any pics of the truck / trailer together from this trip.
bbaxter51 is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 11:16 AM #486
DuckFan DuckFan is offline
DuckFan is on a distinguished road
Originally Posted by Off2Mtns View Post
Do yourself a favor and add air bags but keep the WDH. 5th gen (2016 here) is fine for a WDH. I contacted Toyota about this and they gave me the okay. I posted a copy of their email response... search posts by my user name. I personally think a good WDH with sway control like an Equalizer for a short wheelbase vehicle like ours is a critical piece of safety equipment.
Also, find a way to truly check you tongue weight; I did and surprised myself that I was well over my acceptable 500# limit. Redistributing load got me back to an acceptable level.
2016 SR5 with Firestone bags, stock springs, pulling an est. 3500# (wet) 19 ft TT.
Thanks Off2Mtns!! I will keep the WDH hooked up and will make airbags a priority. Hopefully I can get this thing leveled out better. I know I'm towing near max w/ my 22' Evo T1850 w/ dual-axle.
DuckFan is offline   Reply With QuoteReply With Quote
Old 10-17-2018, 11:19 AM #487
Originally Posted by TEN613RPro View Post
Heed the advice of Off2mtns, it's real world advice. You generally are not as light as you think you are. Actual loaded weights are a must but far from convenient, if you live in or travel through Oregon on the secondary highways you can use the closed DOT scales for free, they never turn them off. These were my eye opening moments for me with my 7.3 excursion and a 30' travel trailer. What surprised me on my set-up was the drive axle weight on the ex, over max but under on the tongue weight limit. You start loading a suv with gear and people it will add up real fast. I re-sprung my ex to match an f250 then tossed my airbag set up. Using airbags for much more than getting your headlights pointed back to where they should be, is just a crutch for being too heavy.
Another consideration if you are running P tires or C's or D's check to make sure you are not exceeding the tire capacity for carrying extra load.
And don't forget the weight of fuel, from fill up to fill up I lose about 300 lbs in the ex, it holds 44 gallons all behind the rear axle. The 4r tank is between axles as you know which helps with these numbers.
Thanks for the tips. I'll have to pull into one of those DOT scales the next time I hook up. I'm very curious as to what my actual weight is.
Old 05-06-2019, 11:01 PM #488
10ga's Avatar
10ga 10ga is offline
10ga is on a distinguished road
10ga's Avatar
The wife and I are taking a vacation down to Lake Lanier in Georgia so thought I would take her 5th Gen on a few test runs with my 21' Triton, I was thinking I could save some stops for fuel. Long story short, I think I'll be better off pulling it with the Tundra considering it pulls the boat like it's not even back there and I'm thinking I'll be lucky to get 10 MPG with the strain on the 4Runner.
Present Toyotas: 1993 FZJ80 Land Cruiser with factory lockers, 1997 SR5 4Runner 4x4, 2007 Lexus IS350
Past Toyotas: 2000 100 Series Land Cruiser, 1983 FJ60, 1991 FJ80 with center diff lock, 1993 FJ80 unlocked, 1995 FJ80 Locked, 1997 FJ80 Locked, 2000 SR5 T4R 4X4.
10ga is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 04:13 PM #489
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Towed pretty decent, but really missed my Tundra.
Towing experiences with your 5th Generation-runner-911-jpg
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 08:16 PM #490
WVhillbilly WVhillbilly is offline
WVhillbilly will become famous soon enough
The 4Runner is probably getting a reprieve from towing duties.
Wife bought an Armada Saturday. Might as well use the biggest hammer in the toolbox.
Think it will do ok towing a pop up?
WVhillbilly is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 04:43 PM #491
lukeskywalker's Avatar
lukeskywalker lukeskywalker is offline
lukeskywalker is on a distinguished road
Originally Posted by 007Tacoma View Post
Honestly, for "mostly highway" the 4Runner is very comfortable, and it does a decent job at towing 3500#. However, when you get closer to 5000# the highway uphill becomes a challenge for the drivetrain. Also, the shorter wheelbase is not ideal for heavier loads. You may want to look at a larger vehicle.
When you say 3500# are you talking about Dry Weight? Or talking about incl water tank full + luggage.
TRD PRO Trim - Bilstein 5100x4 @1.75 - Rear 1.5 Daystar Spacer - F(x) Pro Black Wheels - TRD Skid Plate - General Grabber AT2 @ 265/70R17 - Tail as Turn Rear Lights Mod - HID Low Beam Replacement - BAJA Rack - Flat Utility Mesh w/Sunroof - Sunroof - Fold Flat Cargo Platform - Raingler Cargo Ceiling Net
lukeskywalker is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 01:11 PM #492
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Full. I would not want to tow over 3500# with the 4Runner.
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 06:54 AM #493
RobertAllinson RobertAllinson is offline
RobertAllinson is on a distinguished road
I am using Fit System 81850 Snap and Zap Tow Mirror Pair (2015 and Up F150) for tacoma. That would I guess fit for you too.
RobertAllinson is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 08:56 AM #494
DaveSki DaveSki is offline
DaveSki has a spectacular aura about DaveSki has a spectacular aura about
Late to the game but I regularly tow my 19” ski boat with no problems, in addition to a 22” sailboat and 18” glastron (not at the same time) Lol.
2012 Blizzard Pearl Limited. 17" Icon Rebounds w/285/70/17 KO2s. TRD Pro skid plate. Eibach/Wheelers/OME 2.5"/2" lift. Low Pro Rola rack. USR Blackout Tail Lights, Canadian SR5 front bumper swap.
DaveSki is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 09:27 AM #495
jwscott79's Avatar
jwscott79 jwscott79 is offline
Real Name: Jason
jwscott79 will become famous soon enough
jwscott79's Avatar
Real Name: Jason
I'm sure I was way over the limit, but we made the 4 hour trip successfully...
Towing experiences with your 5th Generation-haulin-jpg
jwscott79 is offline   Reply With QuoteReply With Quote
2010 limited , 4wd , blizzard pearl , towing
