08-09-2010, 08:12 PM
Beach Driving
I'm a new owner of a 5th gen T4R Limited and about to head off to the beach for vacation. I plan on doing some driving on the beach and was wondering how much air, if any, I should let out of the tires before driving on the beach. I've never owned a 4Runner before and just want to make sure i don't do something I'm not supposed to. Thanks for the help, I really appreciate it.
Raz
08-09-2010, 08:22 PM
Raz
I don't have a Limited so I'm not sure if I can give you 100% sound advice, but the only thing I'd take into consideration is the fact that you are rollin' on 20s with very little sidewall. You may want to consider letting out less air than typical. I do know that quite a few people take their Limiteds on the beach on their stock 20s and haven't had any issues. I'm sure there is a thread around here discussing if they've aired down.
Also - side note. Took my TE on the beach over memorial day and had all the windows + back window down. Sand was everywhere inside my vehicle! Its been awhile since my Wrangler beach driving days so I hadn't even considered this. Really was a pain trying to clean out a lot of sticky sand!
::2010 Trail Edition:: ICON Front Coilovers w/Remote Resi's and CDC - ICON Tubular UCAs, ICON Rear Ext-Travel Shocks w/Remote Resi's and CDC - MT Long Travel Springs and Lower Links, 285/70 Goodyear Duratracs, Bronze Countersteer Offroad Type X, CBI Rear Bumper w/Tire Carrier, Shrockworks Sliders and full skids, Pioneer Z120BT, Rockford Fosgate Speakers and Amps, aFe Intake, Aux Battery set up, Roofrack by drabbits, SoCalTrail Behind the Grill Light Bracket
08-09-2010, 08:32 PM
Current: 2010 Limited 4x4, Blizzard Pearl.
08-09-2010, 11:12 PM
Wife and I took the SR5 to OBX two weekends ago and didn't let any air out. Probably should have let some out in hindsight.. the signs said 20 psi but it did just fine. The sand was pretty thick and super soft. In 4H the traction control was going crazy. Going to 4L took all that stuff out of the equation but you were stuck going 3 mph down the beach. 4H was good enough. The only thing that would have helped was something to control L/R wheelspin, e.g. a locking diff.
My $0.02
08-10-2010, 12:20 AM
Rear lockers normally only work in 4L.
I think a limited slip would have been better in that situation.
Check out my garage.
08-10-2010, 02:40 AM
I have been out on the beach several times with no problems what so ever. I air down to 18psi, lock the center diff and turn off the skid control crap, goes fine.
2011 Land Crusier - Black
2010 Limited - Blizzard Pearl
2008 Limited V8 - Shadow Mica
1996 SR5 - Natural White
1994 SR5 - Garnet Pearl
08-10-2010, 06:25 AM
I have taken our 2010 limited out on the beach a few times here in Delaware - I air down to 20 psi and throw it in 4H and good to go. Never had a problem.
08-10-2010, 09:41 AM
Originally Posted by Xiao Yue
Someone explained to me that when the '10 SR5 is in 4WD mode, all four wheels rotate with the same speed/angular velocity (that all four wheels are locked).
That's not true. The SR5 has a part-time 4WD system. That means that when you put it into 4WD, the front drive shaft and rear drive shaft turn at the same speed. But the SR5 has open differentials front and rear, which means that on either axle, the left tire may not turn at the same speed as the right tire. The ATRAC system is what transfers torque side to side, by differential braking.
The only way that all four wheels would rotate at the same speed is if you had a locking front and rear differential (which you don't).
As for driving on the beach, I have an '03 4WD Limited. I use either 4WD low or 4WD high (usually low). I lock my center differential, which makes it perform just like a part-time system in 4WD. I lower my tire pressure to 15 psi.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
08-10-2010, 10:31 AM
The wheels turn at different rates while you are turning which causes binding. The binding causes things to break.
My '98 is also part time 4WD. I run it in 4WD on dry pavement every month, but am very careful not to make sharp turns with it engaged.
08-10-2010, 12:45 PM
That's great news to hear! Others have been saying that I don't have rear/front lockers, and I know for sure that I don't have a rear locker, but I could've sworn that the one time I accidentally left the car in 4WD for a few moments that one of the two front tires had "jumped" a little on the dry pavement.
Why is it not recommended that 4WD be active (on my '10 part time 4WD system) on dry pavement? Does it just wear out the transfer case for the front axle? How does a center Torsen differential, such as the '10 Limited, put less wear on the front transfer case or does the '10 Limited not have a transfer case at all?
Don't drive your SR5 in 4WD on dry pavement. When you go around a corner, as you probably realize, the front and rear of the car take a different line. That is, the rear wheels take a shorter path -- the front diff takes a longer, larger radius path than the rear diff. A center differential, like the Torsen, allows the front and rear diffs to turn at different rates, which lets you go around corners in 4WD. With a part-time system, that works offroad, because the tires simply slip enough to reduce any binding in the drivetrain. On the road, you are adding stress to the drivetrain.
The '10 Limited basically has the same system as all of the 4th Generation 4Runners -- a lockable Limited Slip Torsen diff with a two-speed transfer case.
08-10-2010, 02:47 PM
08-10-2010, 08:35 PM
If you go down to 15 psi, will the TPMS sensors kick in?
Noel
10 Black 4Runner TE, NAV KDSS, WT liners, AVS vent visors, Shrockworks custom step sliders
04 Tacoma Ext Cab V6 TRD 4WD
97 LX 450 ARB'ed and lifted
94 4Runner SR5 V6 4WD
08-10-2010, 09:21 PM
Hmm, that's a good question -- wonder if the '10 4R TPMS looks at absolute pressure as opposed to pressure difference. Anyone have insight?
Not positive how it works, but when I went on the beach I dropped it to around 20-25 and the TPMS light was on
08-10-2010, 10:32 PM
So, Which should you use in sand, 4H or 4L and why? Also, can you turn off the traction control in 4H so it won't go crazy?
2010 4Runner Limited 4x4 - Blizzard Pearl, Navi, Husky Liners, Fiamm El Grande Horn, Yakima DoubleDown 4 Bike Rack
08-13-2010, 10:59 AM
I found that locking the center diff gives better traction in the sand and if I’m not mistaken it automatically disables VSC and leave traction control on. Not sure about 5 gen.
Koz
