Old 08-28-2010, 11:11 PM #31
BBB BBB is offline
BBB is on a distinguished road
BBB BBB is offline
Wink
Originally Posted by mnekaw3 View Post
Can someone put this up on Google Docs so that we can save and print this?
Thanks for taking the time to do all the work!
I added some information (from the inserts on the driver visor).
https://docs.google.com/fileview?id=...CKLu__MB&hl=en
[SIGPIC][/SIGPIC]
2011 4R TE | Shrockworks Rock Sliders | WeatherTech floor liners | Doors side molding | Exhaust tip | Door edge guards | Wet Okole seat covers | Hood protector | Canvasback cargo liners
BBB is offline   Reply With QuoteReply With Quote
Old 08-29-2010, 01:41 PM #32
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Originally Posted by Thai View Post
Well, then (for me) that makes CC and TR useless. I will stick with the "old-tech" A-TRAC and rear locker.
What's TR?
CC is great for the trails that require you to hang out the window so far you can't reach the pedals.
I confirmed you can turn off VSC and TRAC if you hold down the VSC button for 3 seconds but you have to be stationary to turn of the VSC and slow to turn off TRAC. Also tested that it doesn't turn back on by itself at speeds over 30mph (tested to 70). Tested in 2Hi and 4HI.
Last edited by 1000MPH; 08-30-2010 at 12:11 AM. Reason: oops: Doesn't turn back on
1000MPH is offline   Reply With QuoteReply With Quote
Old 08-29-2010, 03:48 PM #33
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Originally Posted by 1000MPH View Post
What's TR?
Sorry, i am used to the Land Rover terminology. It is the same as the multi-terrain selector thingy that you guys have.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 08-29-2010, 09:32 PM #34
BBB BBB is offline
BBB BBB is offline
Wink
What's TR?
I confirmed you can turn off VSC and TRAC if you hold down the VSC button for 3 seconds but you have to be stationary to turn of the VSC and slow to turn off TRAC. Also tested that it doesn't turn off by itself at speeds over 30mph (tested to 70). Tested in 2Hi and 4HI.
That makes sense: VSC & TRAC are for normal driving and should not turn OFF by themselves. It an option for the driver to disable them if stuck in mud or fresh snow by pressing the button. It will turn back ON via the button or by turning engine off, then on.
[SIGPIC][/SIGPIC]
Old 08-29-2010, 10:26 PM #35
BBB BBB is offline
BBB BBB is offline
Wink
I tested the CC (Garcia Trail, CA: see picture in my signature), both going up and down, and it held low constant speed with no slipping whatsoever (did not activate A-Trac or diff lock). It would have been hard to keep such a low constant speed using gas pedal.
[SIGPIC][/SIGPIC]
Old 08-30-2010, 12:07 AM #36
1000MPH's Avatar
1000MPH's Avatar
Oops, I meant they don't turn on when you've turned them off. Someone mentioned the Tacoma does this at 30mph.
Hold the VSC button down for 3 seconds while stationary.
4runner 2010 , drive system , trail , trail edition
