Originally Posted by erik_26
Hello my fellow forum members.
I have a 2015 SR5 4Runner. The front passenger low beam doesn't work.
I have checked the following:
New bulb = good
Lowbeam relay = good
both front lowbeam fuses = good
I have 12VDC at the fuse on the post
I have continuity to chasis ground on the bulb wire socket neautral wire.
I have zero continuity on to ground on the bulb wire socket positve wire.
I have zero VDC on the bulb wire socket to positive.
When I follow the wire harness from the fuse box towards the passenger light, if goes around the battery, behind the radiator tot he other side. It all looks to be intact and protected in the wiring hardness. I can't see it fully when it goes behind the raditor.
So I am not sure if it is a break in the wire somewhere or maybe corrosion under the fusebox, or something else?
Highbeam, blinker and foglight on passenger work. Only the lowbeam does not.
-You bought this 4R used?
-Did the passenger low beam headlight ever work since you’ve had it?
-Did this suddenly happen?
-Are there any electrical mods to the headlight system?
-Are you sure the bulb is good? Did you test it in the driver side headlight?
Check the headlight socket pins for any corrosion or broken wire.
You can check for continuity from the fuse to the bulb. Do it for the driver side (left) as well as the passenger side (right). See diagram.
Good luck.
