With my current set up (E-rated 275/70R17s, slight lift), I'm averaging only around 15 on the highway.
It's all very dependent on wind and speed. A few months back I was driving across New Mexico with boxes on my rack and into a stiff headwind. I got a jaw-dropping 8 mpg for a stretch.
'16 4Runner Trail Edition Premium - BFG AT KO2 275/70R17s - Bilstein 5100s w/ fronts set at 1.75" - Cornfed 1" rear spacers - Rola rack w/ extension
Was on my way back from Santa Fe to Houston recently.....for about 150 miles with the wind and downhill I got 21 MPG. Running 285/70/17 Toyo's. Real world MPG ave is around 17.
That's strange. I also have an AFE CAI, but your tire size should equal better mileage. However, if your KO2's are E load they are very heavy and "may" be a factor. I got rid of my E load KO2's for the C load Ridge Grapplers and wish I would of started with them.
I also have a Sprint Booster, which depending on how you drive, can improve overall mileage, but just by a little. Maybe that's the trick... but who knows.
Just picked up a Sprint booster, from what I read it seems it could help. I'm desperate!
2018 T4R Limited AWD
3500 miles - 17.8 MPG per the dash computer @ 6500' Elevation
4800 miles - after a road trip to Northern NM and AZ - 18.4 MPG per the onboard computer.
As usual, I reset the on board MPG meter at the gas station. Pulled out of the gas station on an empty road with a slight down hill. When I crossed the bridge the MPG meter read 27.2 mpg.
Alas, when I got home, it was back to it's usual 18.7 mpg.
2016 Toyota 4Runner SR5 Premium 4WD Sliver
R.I.P.: 1999 Toyota 4Runner SR5 4WD V6 5Speed_Manual Red
lol, want to see it with some crazy numbers? Turn the key on, DON'T start the motor, then put in neutral and coast for a bit, that is if the gas station is set up where you can coast out of the pump area.
It’s really inconsistent. I’ve had several 4Runner rentals and I drove them like I stole it and have had up to 22 mpg. On my personal 4Runner I drive like Grandpa and I get 15.
SR5 with TRD Pro wheels and tires lift/leveling kit TRD intake and Pedal Commander on city +2
I average anywhere between 16-18 city-highway combined depending on how I drive.
