Old 05-25-2021, 01:22 PM #91
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
Originally Posted by jbstrd View Post
Your issue sounds like you severed an ABS wire that runs along both front spindles. If these wires are stretched too much, they break inside the rubber wire protection. Therefore, you can’t visibly tell it’s broken, you have to test the wire with a meter.
The DLC3 is the OBDII port under your dash on the driver’s side.
The TE’s don’t have DAC, they have Crawl Control instead.
Hope this helps. Unfortunately I still live with the overactive Slip Control issue. That is after two dealer performed ZPC’s and two by myself. Ugh!
I know this is an older post, but it seems like you’re still active here. Did you ever try “faking” out the new calibration? Instead of driving “straight for more than 10 seconds over 25mph”, did you ever try to drive like in a “slalom course” maybe going back and forth between the lines to make the computer think straight yaw/roll/etc is when you’re putting roll into it so the amount needed to trigger the VSC would be that much higher? I though about that as I’m working in Microsoft Project on one of my schedules and I always add fluff into my baselined schedule to give room for error or comfort… I think doing something like this on your new calibration or baseline could help…?
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 01:46 AM #92
NorCal4run NorCal4run is offline
NorCal4run is on a distinguished road
Good information by the person who started this thread but I found this online which is very clear instructions with pics. Take a look!!
My story goes my traction control light was on after Les Schwab Tire in ID did a wheel alignment a couple of days ago on my 2017 4Runner TRD PRO. They said light was go off after driving it for a couple of days. LOL!!
Ya that did not happen
I tried the instructions posted above and it did not work. Why? you have to count 4 from right to left NOT left to right. Once you find 4 then place wire or paper clip in 12 spot under 4.
Here's the link: PS go half way down the page to ZERO POINT CALIBRATION!
Limp Mode on 5th Gen 4Runner & Zero Point Calibration (SOLVED)
NorCal4run is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 01:02 PM #93
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
Just wanted to say thank you again for this informative thread.
Snapped my ABS wire back in 2018 and this helped along the process in getting rid of some lights after replacing my cable.
Just got back from a trip in the Ozark National Forest and on 11/23/21, I ​smacked my wheel against a rock pretty hard. Knocked my alignment out of place as my steering wheel is pointed about 5 inches to the right now. Must just be a change in toe because I marked all my alignment cams and none of them shifted. They also have the Total Chaos Alignment Gussets.
I got slip light on solid and multi terrain light blinking the next day.
Didn't affect me too much as I could use my locker on the the trails.
I'm back home after a 600 mile drive (vehicle drove straight and no chopped up tire wear which was odd considering my steering wheel is heavily off center) and performed the zero point calibration in my driveway and crawl control calibration and it fixed my issue without any hassle.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 04-04-2022, 05:14 PM #94
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
Glad someone said it. I have been reading over this as I have slip and DAC lights on (no ABS) after my lift but that 'enter test mode' statement like we are supposed to know what that means made no freaking sense to me.
Originally Posted by Joe-Runner View Post
Mine doesn't have DAC so I skipped over that. I think you can ignore that "enter test mode" statement though, and just skip to the required steps.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
Old 04-22-2022, 11:32 PM #95
StrykerT4R's Avatar
StrykerT4R StrykerT4R is offline
StrykerT4R is on a distinguished road
StrykerT4R's Avatar
2018 SR5 4x4
Thanks for the post. Wanted to share my experience.
Was offroading and knocked my front end out of alignment. Steering wheel was pointed to the 2:00 position to drive straight and it tripped my traction control light (squiggly lines). Returning home, I inspected my speed sensors and wires and they seemed okay. Knew it had to be out of calibration.
- My TS/CG points were 5 and 13 (not 4 and 12)
- Use paper clips instead of the wires; works MUCH better and easier to make your contacts during the alotted time (look for you tube videos for 5th gen)
-you do not need to drive your vehicle before you reset your DAC (downhill assist); I recalibrated and reset DAC before I drove as straight as possible at or above 25mph, no problems.
Hit me up if you have any questions.
StrykerT4R
So.Cal.
All that is necessary for the triumph of evil is for enough good people to do nothing. -- Edmund Burke (poss)
StrykerT4R is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 02:44 PM #96
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by NorthWest 4R View Post
Did this reset after my lift instal before I ever drove it, still have not set anything off one time or had a problem. Guess it worked
That's where I f_ucked up! I should've recalibrated before driving after lift. My VSC went nuts and nearly took grandma out. The yaw g spot senses more lean than from it's previous zero point data values due to its new higher elevation. It's sensitive. When the brakes are applied while cornering, it also controls the braking forces of the right and left wheels,
helping to maintain vehicle stability. Ebd electronic brake distribution.. definitely something Toyota needs to make known to drivers. Nearly had a really bad time, grandma probably sh1t herself too.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 02:48 PM #97
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Shout out to the Ozarks national forest! I live half my life out there 😍. You know what trails you hit? It's neverending!
Old 05-01-2022, 04:58 PM #98
DCM554 DCM554 is offline
DCM554 is on a distinguished road
help on 2021
Need some help on zero point cal for a 2021 after a clock spring removal. My OBD port only has pins 4,5,6,7 and 14,16 with wires. The older posts with 4 and 12 jumpers obviously won't work. Anyone have an updated procedure for 2021's? TIA Chris
DCM554 is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 05:58 PM #99
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
You shouldn't have to do a ZPC on the Yaw Rate for a clock spring removal? Steering Angle zero point is determined by driving the vehicle straight above 20mph for a short distance; it's not usually something you can manually calibrate with a Scan Tool on Toyotas. If the Steering Angle Zero Point is not calibrating properly and/or setting a DTC; the steering angle sensor could be damaged/failing. We have seen newer Toyotas (specifically 3rd Gen Tacoma and 5th gen Rav4 in my experience) where they were jump started and for whatever reason the steering angle sensor just died (that was covered under warranty, but I never have gotten an answer as to why that happens...)
Why did you take off the spiral cable on a 2021 vehicle? Were you replacing the steering column or something?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 06:13 PM #100
Olivrwendl Olivrwendl is offline
Olivrwendl is on a distinguished road
Cant clear calibration data
I have a 2011 4runner. Recently the horn quit working and I was able to diagnose a bad clock spring. I was able to replace it and get everything working but now I have the power steering light and slip indicator light are on in the dash. I think I need to recalibrate the steering sensor. I follow step two to clear the data , but after touching the wires 4 times my slip indicator light , which was already on starts flashing instead of just being on. When I then go to the next step , the light goes from flashing to just being on. This is the opposite of what should be happening. any ideas?
Olivrwendl is offline   Reply With QuoteReply With Quote
Old 10-09-2022, 08:15 PM #101
Silvr Silvr is offline
Silvr is on a distinguished road
Still relevant in 2022.
Replaced my brake master cylinder on my 08.
Worked like a charm! Saved me a service visit.
Silvr is offline   Reply With QuoteReply With Quote
