Old 07-11-2016, 03:30 AM #31
jasonv jasonv is offline
jasonv is on a distinguished road
couple folks have said "0 at the rear" like there is some other option. there is no other option without new springs or some spacers. the rear are not adjustable
jasonv is offline   Reply With QuoteReply With Quote
Old 07-11-2016, 08:35 AM #32
Decipher's Avatar
Decipher Decipher is offline
Real Name: B-Money
Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough
Decipher's Avatar
Real Name: B-Money
This is exactly where my confusion was. I thought the rears were adjustable, but now that makes sense as to why you must add spacers. Thank you! I've researched for hours and while I'm new to this forum, I'm not new to communities and know better than to post more clutter when the answer is out there.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
Decipher is offline   Reply With QuoteReply With Quote
Old 02-28-2017, 02:39 PM #33
ShortMountain ShortMountain is offline
Real Name: Daniel
ShortMountain is on a distinguished road
Real Name: Daniel
Smile Amazing information
YOU all are amazing... I used the proper search and round this thread.
I have a '11 with 100k miles. stock shocks that SUCK. They are D.O.A.
I shopped and shopped... finally decided on the 5100's front/rear
but did not know how to set them up. Your conversation really helped me! thanks again!
ShortMountain is offline   Reply With QuoteReply With Quote
Old 05-23-2017, 11:44 AM #34
Nsimmons03 Nsimmons03 is offline
Nsimmons03 is on a distinguished road
Just installed 5100's all the way around (3rd notch) with 1" cornfed spacers and 285/70/17 K02's. Had to trim the bumper a little and remove the mud flaps but I think it's looking good. There is also a -12 offset on the wheels. It's my wife's rig and she likes it so that's all that mattered I suppose.
Bilstein 5100 Height Settings-img_0021-jpg
Nsimmons03 is offline   Reply With QuoteReply With Quote
Old 02-19-2018, 11:23 PM #35
LanierT4R LanierT4R is offline
LanierT4R is on a distinguished road
Does anyone have experience with the 5100’s set at 1.75 w/stock rear springs and a hybrid winch bumper like the C4 Fab Lo Pro?
What impact if any will the bumper and winch have on the stance?
LanierT4R is offline   Reply With QuoteReply With Quote
Old 02-23-2018, 10:59 PM #36
sarsipius sarsipius is offline
sarsipius is on a distinguished road
I picked up a used set of Bilstein 5100's for my SR5... They were previously installed on a TE and have the TE coils already attached. Does anyone know if i can simply swap out the SR5 stock coilovers with the used billsteins and TE coils.... I know that the SR5 has only 7 coils on the drivers side, where the TE has 8 coils on both drivers and passenger.
sarsipius is offline   Reply With QuoteReply With Quote
Old 02-23-2018, 11:21 PM #37
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
I had this exact setup when I installed my SSO hybrid bumper in late 2014. The combined weight of around 130 pounds made my front springs sag about 3/4". I drove it for a few months that way until I could afford a pair of OME 2" 885's to offset the weight, and I set the 5100's at 0 to keep it close to what I had for front lift before. Still running that setup 3+ years later up front.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 01:11 PM #38
4Runner_Gunner 4Runner_Gunner is offline
4Runner_Gunner is on a distinguished road
Originally Posted by Michigander View Post
I installed the Bilstein 5100's on my tacoma, which is pretty much the same front end as the 4runner.
Some notes:
- You have to completely remove the strut from the vehicle and remove the spring to adjust the height of the shock bucket. You need to use a spring compressor to eliminate pressure on the bottom spring cup and circle clip.
- I had my truck set at 1.75" lift and the ride becomes more harsh because you are preloading the spring to increase spring stiffness. I would suggest running it at the lower setting.
- The rear should be slightly higher than the front unloaded. The rear springs on the 4runners are soft and they will sag when you load the truck with people or gear. You don't want your headlights pointed to the sky when you have a load in the truck.
- When you get to 1.75-2.5" of lift, the front end is more difficult to get a good alignment (positive caster) and upper a-arms may need to be replaced with aftermarket to get good numbers. My truck was really twitchy in the front steering due to not enough + caster.
The same thing happened when I had the 5100s installed on my 2012 4runner. I did 1.75 up front with a 1inch cornfed spacer in the back. The ride feels twitchy, and I feel like i am actively correcting the steering.
4Runner_Gunner is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 11:36 PM #39
SR52011's Avatar
SR52011 SR52011 is offline
SR52011 is on a distinguished road
SR52011's Avatar
Are you still running 1.75/1, has it gotten better over time?
SR52011 is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 09:33 PM #40
MannMade82 MannMade82 is offline
Real Name: Jason
MannMade82 is on a distinguished road
Real Name: Jason
I have had mine set at 1.75 with rear 1" Cornfed spacers for almost two years and I have zero complaints. Just get it aligned after the install. I installed them myself, solo...not hard to do if you are handy and have tools.
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
MannMade82 is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 10:44 PM #41
SR52011's Avatar
SR52011's Avatar
I got mine fine today at 1.75/1. Looks great! I wonder if I can now add 285s with minor trimming to give me around 1 inch additional height.
Old 08-12-2022, 10:20 AM #42
fpainter fpainter is offline
fpainter is on a distinguished road
radar cruise control issues
I have the 5100s on the workbench. I am a little worried about the radar cruse control and pedestrian warning camera. Does anyone have a 2020 or a 2021 that has had issues?
fpainter is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 12:55 PM #43
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
I have heard of users on here running asymmetrical lifts and not needing to calibrate the radar / TSS.
Same with new Tundras and Tacomas it doesn’t cause an issue.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 03-19-2023, 03:52 PM #44
Just installed my 5100s with a 1.75" lift in front. The front and rear wheelwells are the same distance above the ground, and the front axle shafts are perfectly level at ride height. The radar cruise control works, and the vehicle handles just fine. Does anyone know why Toyota made the stock front ride height lower? I will guess that they were chasing gas mileage. The rear shocks came with instructions that were wrong, they show the washers in the opposite configuration that they need to be in.
Old 03-19-2023, 07:14 PM #45
stiles_s stiles_s is offline
stiles_s will become famous soon enough stiles_s will become famous soon enough
Why did Toyota give it a slight rake? Maybe to avoid dragging its a&@ when you throw a bunch of weight in the cargo area or a heavy trailer on it?
'22 4runner Limited (ORP 17s)
'18 MacanS (wife's)
'10 997S
stiles_s is offline   Reply With QuoteReply With Quote
