Originally Posted by Riser
Thanks. I'm assuming the sensors have to be removed and installed when dismounted?
You can just leave them on the TE wheels and have a tire shop scan them into your TPMS ECU on your Limited. Takes about a minute, they walk around to each wheel and hit a button to read the id of each TPMS and then they stand by the drivers door and hit enter and it will read confirmed on a Bartek scanner. I had it done 4 times already. Discount tire store around here does it for their customers for free. The dealers rip you off and charge like $50 or something for a 1 minute job.
Having them dismount and rebalance the tires and swap them over is going to cost money. Plus the little rubber o-rings on the TPMS are not supposed to be re-used after they are taken off and will have to be bought.
