Originally Posted by ningduo
1. anyone experience "a click" under the steering wheel after you startup your truck and reach the speed about 3-5mph (no matter in Reverse or Drive)
Yes, normal, abs/brake system doing its 'thing'. Do a search, it has been discussed a few times here if you want more details about it.
2.Right after back up form the parking lot and put the shift to drive, when I hit the gas pedal. I saw the low fuel indicator blink about 3-4 time (gas tank almost full) and I can feel a valve or switch under the gas pedal disconnect and reconnect. I cannot feel any power output while the low fuel indicator blink and it last about 4 second. This problem only happend twice after each time I fuel up my truck (I only fuel it twice for now) and drive about another 2-3 gallon distance.
Sounds like you might you are still 'rolling backwards' when you shift from R to D. Are you sure it is the low fuel light? Sounds like you might be activating the HAC system or possibly even the TRAC system (the TRAC system senses 'slippage' and will flash lights on your dash, make clicking noises, and cut power to the engine). These new 4R are very sensitive. Make sure you come to a complete stop before you shift and let us know if it still does it. Also, are you turning your engine off while you fuel or do you leave it running?
