Originally Posted by dezertbomber
Nice job doin it right, which certainly takes time, but is worth it.
installed the full skid yesterday. for anyone else thinking about this one area of confusion I had was the bolt part number. P/N 90080-11373 are the screws you want, those are what I used (used them for the front skids too). M8-125x20mm stainless also will work as well (I tested them too). the P/N above does not show up as the standard screw when looking at the part diagram for the skid plate, a different part comes up. however, these bolts worked perfect. the skid plate # above for the full skid is what I ordered as well, careful not to break the plastic hose protector unless you order a new one when transferring
most people here will just order after market skids which there are some really great options. but anyone not living in the USA the full OEM skid that comes with the trail isn't a bad choice by any means for only a few hundred $, it's better than the half skid and much cheaper when you factor in shipping, taxes and duty than the aftermarkets
