12-07-2010, 05:19 AM
transmission temp gauge/monitoring
I've seen a few people post up their tranny temps while towing. What are some ways to monitor transmissions temps? I wouldn't mind having a gauge for it, but I wouldn't know where to tap in. Perhaps just a sensor inline in the tranny cooler hose that goes to the radiator?
Otherwise, is this temp already monitored and available with an OBD reader?
-joe
2011 Trail, BFG A/T tires, Spidertrax wheel spacers, Toytec top plate spacers
12-07-2010, 10:02 AM
I would consider using the ScanGuage which can be found on Amazon.com for about 150$.
Good luck
2010 4runner limited with nav, sliding tray, cross bars,
silver metallic, hood protector, 3M, all weather floor liners, locking wheel nuts, Super Bumper 4"
12-07-2010, 01:44 PM
Good luck
iDriva4R has a Scangauge. He can tell you what it scans. I am not sure if our 4Runner already does tranny and oil temp. I don't think it does, but I could be wrong.
12-07-2010, 02:29 PM
I do have a ScanGauge, but it's an older one without the Xgauge feature. I guess it's about time I trade it in for the newer ones.
-joe
12-07-2010, 09:33 PM
I think the issue is does our computer record the tranny temps? Or do we need to tap into the line and buy an aftermarket gauge?
Does anyone know the answer - do we need to buy a tranny thermometer or does the computer record this temp and can we pull it using the scangauge?
12-07-2010, 10:35 PM
there is a trans oil temp light on the dash
12-07-2010, 10:59 PM
Real Name: Gary
Real Name: Gary
I have the scangauge with x-gauge and no it can't read the tranny temps.
Funny thing is .....reading thru the factory repair manual I don't even think there is a external temp sensor on the a750 tranny to tap into to get a reading up to a gauge. I found the one on the a343 which is the 4 speed tranny.Maybe ,somebody else read the manual to see if I missed something here.
Also the only way to add fluid or check the fluid level is to fill it until it comes out the overfill plug hole. It does have procedure to check temps.....all it says is to put in fluid detection mode and idle speed control mode and then adjust the temp.to the specified value. It does have a cooler already as I was looking to relocate the lines.The tranny cooler is internal to the radiator I believe with lines coming out both sides on the bottom of the radiator.
One thing about the a750's is they are a very,very reliable and have been so for years.! I don't think that I have ever read about a problem with them although I'm sure there had to be some. Lot of complaints about rough shifting and the shift points but not about reliability!
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
. ...........Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
02-01-2012, 04:19 AM
Real Name: Jeff
Real Name: Jeff
Yyyyyyyyyyyessssssss!! Time to buy a Scanguage...again.
HERE FISHY FISHY FISHY!
02-01-2012, 11:09 AM
After going through a few threads people were having difficulties because of their firmware. I bought my sg2 nov 2011 and it had the 4.06 firmware on it. I had no problems programming it. Hope that helps!
02-01-2012, 01:10 PM
If you have a Garmin unit you could get this to go along with it to read it....
https://buy.garmin.com/shop/shop.do?pID=38354
I do have an OBD II reader but have not checked to see if I can read the tranny temp.
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
02-02-2012, 01:31 AM
Is this the right one?
02-02-2012, 05:01 PM
Thats the one, needs to have the xguage capability. I bought mine about a week ago and it does work.
02-02-2012, 07:54 PM
From the description:
The ScanGaugeII has been redesigned with expandable Add-A-Gauge (aka XGauge) technology. Add to the original 12 gauges by customizing the ScanGaugeII to monitor up to 25 more--depending on your specific vehicle's sensor design. Four gauges can be displayed simultaneously and can help determine fuel consumption rates, allowing you to adjust driving behavior and save gas. At the same time, keep an eye on coolant temperature, engine speed, and much more in real time. If there is a young driver in the house or friends borrow your car, the ScanGaugeII can record speeds of up to 158 mph and store the information for you to view later, so you will know just how fast your young driver or friend was going last night. If the unit was disconnected, you'll know: An indicator will be displayed in the trip data.
02-02-2012, 08:39 PM
On the scanguage website it states that it does have trans temps for a few toyotas. here is the link.. This is with X-gauge
Toyota Specific : Linear Logic : Home of the ScanGauge
It does say yes. I haven't tried it yet.
