Old 12-02-2010, 12:22 AM #1
CApilot78 CApilot78 is offline
CApilot78 is on a distinguished road
Will it FIT with a lift and baja rack in the Garage?
The 2.0" OW vs 2.5" OW thread is awesome. I spoke with Andries and was initially going to go with the 2.0, but now think I will just spend the extra $500 for the 2.5"
Anyway - Will it fit in my garage. I have a Baja Rack on order and going to get the 2.5"OW lift.
My garage is 80.5 inches to the "weather strip" on the top of the garage and 81.0 to the actual stucco.
My stock 4runner, from the top of the current roof rack (above the 2nd row seat - front of the rack) to the weather strip is 9.0 inches. (I think this means my stock height from ground to roof rack (above the 2nd row seat) is 72 inches.
It is my understanding the Baja Rack is 5 inches (is this correct?) from the roof to the top of the rack, and if I go 2.5 inches lift, I should be good? - 1.5 inches to spare? 9-7.5.
If I put on the lift and I get it home and it doesn't fit, my wife will have me sleeping outside with the dog.
Anyone else have a garage height issue, how did you deal with it?
CApilot78 is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 12:56 AM #2
hamiltonj2w1's Avatar
hamiltonj2w1 hamiltonj2w1 is offline
hamiltonj2w1 is on a distinguished road
The basket is 5 inches that doesn't include the mount I believe I read somewhere that is is 7 1/2 inches from the roof is the total height of the basket don't quote me on that one. But if what I read is true your going to gain about 3 1/2 to 4 inches taller then the factory rack. In my Garage with my lift and 33's I have about 6 inches of clearance still but this is on a trail and the racks are a little taller not sure what you have?
(Edit) See post 84 says it is about 6 1/2 from the roof NEW 5th Gen BAJA RACK
2005 Sport Edition 198k miles, 4.7V8, Daystar lift, BFG Mud Terrains in 255/75/17
1976 CJ7 (Off Road Toy)
Past 4Runner's 97 SR5 (Sold) 2003 Limited (Sold) 2010 Trail (Sold) 2004 SR5 (Sold)
hamiltonj2w1 is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 01:18 AM #3
iDRiVaT4R's Avatar
iDRiVaT4R iDRiVaT4R is offline
iDRiVaT4R is on a distinguished road
iDRiVaT4R's Avatar
It should just fit. I think my total truck height with rack is around 6 and a half feet. I'm 6.3 and it's just a few inches taller than me. My garage door opened height is about 7 ft. It has about 3-6 inches of clearance. You should be ok.
I might be selling my Baja rack here shortly, they are in the process of creating a flat utility style full length rack.
Current Ride: 2004 Toyota 4Runner Sport V8 4x4
iDRiVaT4R is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 01:28 AM #4
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
Keep me in mind if you do sell your rack. I want a Baja and if i get one slightly used for a better price why not.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 01:57 AM #5
azn-sensation azn-sensation is offline
azn-sensation is on a distinguished road
definitely gonna be keeping an eye out. baja racks rock!
azn-sensation is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 05:16 AM #6
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Don't have a 5th gen but I do have the OW 2.5 suspension with a BajaRack.
My garage door entrance height is 7ft and I fit with about a 1 to 1.5 inches to spare.
But you have a 80.5 inch entry which is only 6.71 feet so it might be a little tight.
What size tires are you running and what kind? MT or AT?
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 12:17 PM #7
Snooperstyle's Avatar
Snooperstyle Snooperstyle is offline
Snooperstyle is on a distinguished road
Baja Rack is definitely 6.5" above the roof of the truck. Just confirming that. You may want to consider the possibility of what you will have on that Baja Rack as well...such as Hi lift jack, additional crossbars like I have, or a spare tire, or whatever else you might put up there on a semi-permanent basis...
My garage is about 80" at its lowest point, and my truck is about 77 or 78" high with Baja Rack and 275/70/17 BFG ATKOs. So, if I were to get a lift and bigger tires, I would be cutting it REAL close.
As mentioned before, you have to consider the diameter of your new tires after you get your lift too. If you go with 285s, I think those are about 1.2" taller than the stock 265s, and I don't know if these online tire calculators take into account the extra tread on a MT or AT tire. If you go with 305s, then you are over 2" higher than stock.
2010 LTD 4x4, blk/sbl, nav, remote start MODS/ADDS: TE Conversion; ICON Stage 2 w/ LRUCAs; 285/70/17 DuraTracs; Baja Rack; SW Sliders, ARB CKMA12 onboard air; Fiamm horns; Tan Huskys; 30% tint; 5" mangowalk; LED lights in interior, puddle lights, license plate, engine compartment, and cargo area; small tool box under the hood; removed cargo tray stopper; reverse cam switch; 4-pin trailer light hookup relocation; K&N air filter; AVS bug deflector; 3m carbonfiber chrome coverup (except door handles); midland CB; Firestik 2' hood-mounted CB antenna.
Snooperstyle is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 12:20 PM #8
Also, make SURE you measure the LOWEST point when you garage door is open. The lowest point on mine is NOT the weather stripping. It is where the metal arm comes down...the one that is hooked to the chain to pull the door open and push it closed.
Old 12-02-2010, 01:12 PM #9
I just measured my truck with my lift and 285's I am at 77 inches my garage is 82 so I am only going to have about 2 inches to spare if your garage is only 80 it might be close.
Old 12-02-2010, 02:02 PM #10
When the garage door is open, my metal arm is NOT the lowest point any more. It is 16 inches above the roof of the SR5.
So I re-did my measurements from my roof, not my roof rack. My roof (back by the XM antenna) to the weatherstripping is 10.75 inches. I need 6.5 from the roof to the top of the baja rack. Which leaves me with 4.25. the 2.5" OW lift will add, at most 3", so I should be good by 1.25 inches. So no new tires for me it looks like.
I am going to add the Baja Rack first, come back, measure and then see about the lift.
Thanks for the help/ideas.
Old 12-02-2010, 03:42 PM #11
Going from a 265 to a 285 is only going to raise it 1/2 an inch so if you have should have enough room I would lift it and do tires then measure for the rack if it were me. Or you could just level it and go 275's and do the baja rack is always another route?
Old 12-02-2010, 05:09 PM #12
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I'd love to see the new rack...sounds friggin' HOT
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 08:40 PM #13
iDRiVaT4R's Avatar
iDRiVaT4R's Avatar
My garage opening is 84". My 4runner with rack is about 80-81" at it's highest point.
Just took this with my iPhone as I was half way under the opening.
Old 12-03-2010, 02:49 PM #14
Tire size calculators online say it is a gain in diameter of just over an inch...how did you come up with 1/2-inch gain? Did you do actual measurements on your tires and your stock tires? If you did actual measurements, it will be important to note the inaccuracy of online tire size calculators. Or are TE stock tires a different profile ratio than 70? Not hatin'...just want to make sure the info is accurate for this guy and others.
Old 12-03-2010, 02:55 PM #15
ssmathis ssmathis is offline
ssmathis is an unknown quantity at this point
Snooperstyle, remember that even though you get 1" total gain in diameter, that only equates to only 1/2" gain in height. Half is on top of the tire while the other half inch is the extra height off the ground.
ssmathis is offline   Reply With QuoteReply With Quote
Baja Rack for 3rd generation 4runner is on... bigwapitijohnny 3rd gen T4Rs 35 11-03-2016 02:30 PM
