Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 08-14-2020, 06:14 PM #196
Blue Spark's Avatar
Blue Spark Blue Spark is offline
Blue Spark is on a distinguished road
Blue Spark's Avatar
Intresting, i wouldnt mind deleting my rack. Ive already removed the cross beams
15 TE | 20.5 Mpg avg
Blue Spark is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 07:11 AM #197
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
I'm surprised the OEM delete kit doesn't come with any mastic patches. When I removed my rack for the first time the mastic got messed up so I ended up buying new mastic tape when I put it back on.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 06:42 PM #198
Hfdjarhead Hfdjarhead is offline
Hfdjarhead is on a distinguished road
Replacement weather stripping
I have had the roof rack delete working for about 6 months. Somewhere along the line I have lost the weather stripping that runs along the top of the roof. Automatic carwashes are not our friend...
Anyone have the part number for the replacement strips? Many thanks
Disregard, found the part number... This is an issue though without the rack to put pressure on the strip, it may fly off on the wash...
Hfdjarhead is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 07:17 AM #199
icestud's Avatar
icestud icestud is offline
Real Name: Matt
icestud is on a distinguished road
icestud's Avatar
Real Name: Matt
Has anyone removed the plastic covers from the Delete kit? is there a right way to remove them? I did the Delete about two years ago and now I'm getting a leak, I did not use the silicone, so now I will remove the caps and redo the bolts with the tape and silicone. Any advice is appreciated
Thanks Matt
2023 TRD Pro Solar Octane Westcott Lift, Dobinsons UCA, Westcott 0 degree no Kick Out, No top plate Sliders, Ugly Rack Removed
icestud is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 11:59 AM #200
toomanytacos's Avatar
toomanytacos toomanytacos is offline
toomanytacos is on a distinguished road
I'm rack free as well for now. I really like the smoothie look. When I bought mine used, it had a TMT rack on it that I removed due to rust (sold). I went and sized the bolts at the hardware store and bought some shorter ones. Siliconed them up and reinstalled. Sadly the previous owner removed the long black gutter covers completely so I can't hide my bolts.
2016 T4R Trail
Mobtown Offroad Steel Skids
+ all the mainstream Overland junk
toomanytacos is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 09:40 PM #201
rook_group rook_group is offline
rook_group is on a distinguished road
Just out of curiosity, does anyone else have an issue with the plastic covers from the kit not lining up well with the weather stripping?
rook_group is offline   Reply With QuoteReply With Quote
Old 10-25-2021, 02:06 AM #202
HubadaX2 HubadaX2 is offline
HubadaX2 is on a distinguished road
Curious here to, did the install, all arrows out, but the covers are all not inline with black weather strip on the roof. Does yallz line up perfectly?
HubadaX2 is offline   Reply With QuoteReply With Quote
Old 10-25-2021, 02:08 AM #203
Same issue here lol, I have a small gap on the outside edge on all 4 covers
Old 01-05-2022, 08:27 PM #204
FireTiger's Avatar
FireTiger FireTiger is offline
Real Name: Sean
FireTiger is on a distinguished road
FireTiger's Avatar
Real Name: Sean
Originally Posted by mswaz View Post
I tried doing this today and got scared a couple of bolts in that it was stripping the threads. Its much harder on the Pro as the bolts are torx 40 whereas as on the other models racks the bolts are standard socket heads.
The effort to remove them was too much, too much torque required actually broke one bit. Some came out easier, some would get so hard partially threaded out that something seemed off. Still like to remove the ugly things of my '19 pro. Must be loctitie on these bolts for the pro rack. I did this on my '18 landcruiser and it was a piece of cake.
Any ideas?
I just did this on my PRO. Followed some great You Tube videos and BINGO, one of those stupid torx heads stripped. 7 of 8 came just fine. For such a high-end vehicle, Toyota felt the need to use cheap metal torx bolts. So, now, I drilled the stripped head off and tried everything from torching the bolt itself to heat up the absurd amount of Loctite Toyota uses, to vice grips which even the needle nose type are too large to get in the space to remove the remaining threaded bolt stem, and even so, neither item, even with tape or rubber band wrapped around the stem for extra grip, is secure enough to get it out. I am now looking to this forum for how to remove the headliner without damaging it and twisting the entire gasket it is screwed into as a leverage to get it out from the bottom. If anyone has any info on headliner removal related to these PRO racks, please help. This hopefully gives you some help. If I could have ordered my PRO new, I would have requested it without the darn rack. UGh!!!
Firefighter
FireTiger is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 11:30 AM #205
Joewildlife Joewildlife is offline
Joewildlife is on a distinguished road
Originally Posted by 4RunnerAZ1 View Post
Great write up, I ordered and installed the roof rack delete kit. I want to also warn about using a screwdriver even with a rag I managed to put a small dent in the upper roof area below the cover, I used a plastic dent tool to pry the covers off after seeing what I had done. Good thing I bought the paint/dent insurance, they will remove that dent I knobheadingly put on my vehicle. Reason I removed the rack, it's silver, nothing on my truck is silver, and I will never have a need to use it, and as others have mentioned, it's a pain to wash/wax the roof with that rack in the way.
I want to either remove and paint or replace with a black factory rack, the rack on my 2012 SR5, or remove it completely and replace with a Gobi.
Anyway, your truck looks great and I also want to get rid of all the chrome.
Joe
2012 4Runner SR5 4WD
2011 Tundra Doublecab 5.7L SR5 4WD
2013 Highlander AWD-Better Half
2005 Highlander AWD V6-Daughter
2006 Highlander FWD 4cyl-Son
Joewildlife is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 09:18 PM #206
ibilintuc ibilintuc is offline
ibilintuc is on a distinguished road
done
done:
DIY: Roof Rack Delete (w/ pics)-topless-jpg
ibilintuc is offline   Reply With QuoteReply With Quote
Old 01-02-2023, 08:35 PM #207
GreatDane68 GreatDane68 is offline
GreatDane68 is on a distinguished road
I'll be ordering the parts to do mine tomorrow.
GreatDane68 is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 05:58 PM #208
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
I ordered the Toyota OEM rack delete kit off of Amazon, but I’ve since added antennas and decided to keep my side rails on.
It may as well get used and not sit around in my garage, so if one of the members here is interested, shoot me a PM.
hoppyjr is offline   Reply With QuoteReply With Quote
Old 04-10-2023, 01:45 PM #209
icestud's Avatar
Real Name: Matt
icestud's Avatar
Real Name: Matt
Anyone know if the same Parts will work for a 2023 Pro?
Old 04-10-2023, 01:48 PM #210
They haven’t changed the rack or the vehicle, so should be no issue.
Roof Rack Advice tbm General Discussions 29 06-24-2016 04:44 PM
Roof Rack Delete Part Numbers Joaco10SR5 5th gen T4Rs 7 12-14-2010 07:49 PM
roof rack vthokie 3rd gen T4Rs 8 11-01-2010 01:10 PM
07 4runner Roof Rack sampsonite Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-20-2009 10:15 AM
Roof Rack Removal Help :( Shoke 3rd gen T4Rs 9 10-31-2009 06:45 PM
