04-23-2014, 08:39 AM
#31
Real Name: John
Real Name: John
New member and I just came across this thread. I noticed a number of suggestions for waterproofing the bolt holes. One suggestion I did not see was the use of teflon tape. It is used in plumbing applications for threaded connections under pressure. It would seem to be more than adequate for stopping any water leakage and it has the added benefit of being easily removed (unlike a loctite solution).
Anybody try this or have any thoughts about using it.
04-23-2014, 10:42 AM
#32
I did used teflon tape on all of bolts and is working great after a few years of car washes and rain storms.
Joaquin
2010 4Runner
2016 BMW M235i
04-23-2014, 01:07 PM
#33
i used Teflon tape on the bolt threads and a little silicone around the bolt heads for the ones where the gasket material came up when removing the factory bolts. (unlike SR5 & Limited, 10-13 Trail Edition already has the brackets and gasket underneath) a couple came out perfectly clean and left the gasket sealed in place intact; Teflon tape on threads only for those. been about a year. no leaks so far.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
04-23-2014, 01:15 PM
#34
Originally Posted by W8kbrder
In front of the Rado is a 1971 Series IIa Land Rover w/ Defender 90 axles/coils, transmission and transfer case, military spec engine w/ headwork, etc etc. I'm a huge Rover fan.
That Land Rover is cool beyond words! If you have a build thread anywhere on the interwebs, I would love to see it!
04-23-2014, 03:37 PM
#35
Real Name: John
Real Name: John
SandCrawler--does that mean I might only need to acquire the plastic covers after removal of the brackets with no other hardware necessary. I have the 2014 TE.
04-23-2014, 05:54 PM
#36
the 14+ Trail has the same roof rack as the SR5 & Limited so i can only assume you need the complete kit (bolts, brackets and covers) as laid out in the first post in this thread.
btw "@" in front of a username (exact spelling) generates a "mention" which shows up in the user's control panel, letting them know there's someone asking a question, etc. like this:
@ JAD
good luck.
04-23-2014, 06:55 PM
#37
I recently developed a leak from the rear driver's side rack fitting. I pulled it off and went to town with 3M 4200 marine sealant. In theory it should be water-tight from the factory, but after miles on the road with paddleboards and gear tugging at those bolts, I have little confidence in a rubber washer. My solution isn't pretty, but it sure as shit won't leak. 4000 / 4200 is good stuff and if needed, can be disassembled. Stay away from the 5200 unless you like heat guns, hammers and crowbars.
2010 Silver Trail Edition
04-23-2014, 07:33 PM
#38
Any pictures you got on how you did it
04-23-2014, 07:51 PM
#39
No pics, unfortunately. I simple pulled the bracket and bedded it, ensuring that sealant worked its way between the sheet metal and the plastic tubes extending inside. I reattached the rack and put plenty of sealant on the threads of the screws.
In the process, the fitting that holds the backing plate for the screws fell off inside of the headliner. As an added bonus I got to learn how to take that down, as well as find out how sensitive it is to prying. Enjoy
04-24-2014, 08:17 PM
#40
Ever thought about using windshield glue
04-24-2014, 09:33 PM
#41
I imagine there are plenty of options out there that would work. I use 3M on my boat and it happened to be handy. I hate to see a whole tube go to waste...
06-26-2014, 05:05 PM
#42
I might just be overlooking it in this thread, but where di you order the parts from?
06-26-2014, 06:15 PM
#43
My local toyota dealer
2014 TE-KDSS
OPOR sliders, RCI aluminum full skids+(gas tank & A-arms), Icon Stage 2 w/ 3in overland springs, Cooper ST Maxx 255/80, Undercover HWMS w/ Superwinch Talon, K9 2.2
Daily:99 rav4 - OME baby lift, 31s, 5 speed Past:91 LC - built
07-13-2014, 04:27 PM
#44
Thanks for the how to post. I was installing factory cross rails so I only needed the first part. For removing the caps, I used a stiff blade putty knife with a beveled edge as well as a rag. The blade is 1.5" wide so it better distributes the load and the leading edge is almost knife thin.
The cheapo molding and trim tool set from HF would probably be good for this too.
White 2014 TE "Ms Piggy"
07-24-2014, 09:34 PM
#45
Thank you for posting this DIY. I just removed the factory rails, then didn't like the naked look, and put them back on (with thread locker and some RTV for the belt + suspenders approach).
Re: removing the rail caps, I first gently heated the caps with a heat gun. For the prying, I used a carpentry grade 2" wide chisel, covered in painters tape. Bevel side of the blade up. Worked very well.
-Mawgie
