06-16-2017, 06:35 PM
#331
well, its pretty quiet under normal load. You will hear it growl at WOT.
06-16-2017, 10:48 PM
#332
I understand that. I am inquiring to see if anybody is experiencing a whistle
More is better
06-17-2017, 06:56 AM
#333
mine whistles. always has.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
06-17-2017, 08:14 AM
#334
Real Name: Brett
Real Name: Brett
The growl my TRD cai makes was almost startling at first. Tough sounding indeed. Installed my snorkel and it pulls so much air through at WOT, the grate on the snorkel vibrates pretty loudly.
It sounds like a ricey muffler. It's kind of cool sounding, cause it's only after about 3500 rpms. Otherwise it would start getting annoying. I did wrap a little e-tape around the outer frame in a couple places to shim it out, it helped a little.
Definitely happy though. With the addition of the URD crossover and a Magnaflow to go with the CAI, the Low end torque has improved, so at 5980 lbs on the CAT scales it really helps get this beast moving.
I do have a slight whistle (possibly the WT rain gaurds creating it off the snorkel) but not enough to bother me.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
06-17-2017, 12:35 PM
#335
Did you plug the hole in the side of lower box, or was it plugged when you bought the whole unit preassembled?
More is better
06-17-2017, 04:12 PM
#336
Attachment 256268
It sounds like a ricey muffler. It's kind of cool sounding, cause it's only after about 3500 rpms. Otherwise it would start getting annoying. I did wrap a little e-tape around the outer frame in a couple places to shim it out, it helped a little. Attachment 256269
i noticed with the snorkel, it really brings the CAI to life..
06-17-2017, 05:53 PM
#337
oof. it's been a long time since i set it up. but if i recall correctly, there were no holes in the lower airbox... or if there was, that there was a grommet/plug provided to fill it in.
06-17-2017, 10:07 PM
#338
I purchased my order pieced out from camel back. There was a hole in the lower box that i plugged, as well as a hole next to one of the grommets that i left alone, should that be plugged?
More is better
06-18-2017, 02:15 AM
#340
Originally Posted by Saker
Yes......
Fiddle stcks. Time to take it apart. Just so we're clear, this is the hole on bottom of lower box that is adjacent to one of the rubber grommets that was transferred from old box? I bought silicone sealant to seal the hole on the side with a push plug. Any suggestions on what i could use for this square-ish shaped hole?
After digging through this thread for the 100th time i found my answer, just sealed the hole on bottom of box that is adjacent to grommit with silicone caulking. Thanks again for all your help
More is better
Reason: Found my answer in previous thread
06-26-2017, 02:00 AM
#341
official vendor
Real Name: Brenan
official vendor
Real Name: Brenan
You can definitely hear a whistle, it almost sounds like an STI turbo but not as loud. I also have mine hooked with the Magnaflow exhaust (which I installed before) so it's getting a bit more throaty from that. It is more of a "Whisp" than a whistle. It's very subtle. But after dropping in the intake, the sound is much deeper with the Magnaflow. But, not as deep as a pair of Flowmasters would be.
All in all, I think the TRD intake is an awesome addition. Also, since the pictures are not pulling from photo bucket in the first post, here is our full step by step install ( TRD Intake Install 4Runner). Also the Magnaflow install: Magnaflow Install 5th Gen Runner
My 4Runners; 1999 SR5 4WD Jade Green, 2014 TEP KDSS White, 2016 SR5P White, 2016 TEP KDSS MGM (Jade) and 2023 SR5P on Portal Axles.
Trail 4Runner (5th Gen 4Runner Mods): Trail4R.com
6th Gen 4Runner Mods
https://6g4r.com/
06-26-2017, 10:44 AM
#342
for those with the whistle, are you running the stock filter or the TRD filter? I'm running the stock filter and hear no whistle...
The TRD one has the steel mesh like a K&N I believe, which could cause the whistle.
2016 Trail and half of an early 90s Ford Ranger
06-26-2017, 11:00 AM
#343
running with stock filter and i do have whistle sound..
2016,Super White,SR5 4x4P
06-26-2017, 11:38 AM
#344
Real Name: Frank
Real Name: Frank
Originally Posted by socalka
Did you ever do this? did it work out?
I apologize for the delayed response. Yes it worked. I had everything except for the filter plug meter. Which I just capped off with a standard black plug.
2015 4Runner SR5 4x4 - Shiny things and some blue springs
06-26-2017, 12:20 PM
#345
Does anybody have actual part number for the whole unit? My local dealer cant seem to find it and asked for a part number. I have a 16 Limited, is it one part number fits all or are they by the models? Whats the cheapest place to buy it if the dealer cant find it? Thanks
