Originally Posted by Antman
I did it after reading Harper7's post. You CAN get those off without taking the panels out- that's how I did mine (both sides). I grabbed the edge closest to the side window and pulled up with a trim removal tool until I could get my fingers in there. Then -scary part- kept pulling until the tabs with the screws broke. You will cut that part off anyway. They break away cleanly without damage to the wheelwell plastic. Then you trim some clips -see Harper's Post- so they can be popped out easily and you are done! I put some trunk carpet in mine to keep it quiet in there. It's a great help when running wiring too. Thanks harper7 for the idea!
Hello
New to this forum. I see this is an old post so I'm not sure you will see this reply. If you do, I wanted to know if wiring can be fed from the driver side floor panels that can be lifted up back through to the open space under the driver side wheel well tray. Another feed talked about removing the entire quarter panel, which isn't something I'm interested in doing. I want to mount my battery management system on a molle panel back there and want to bring the wires to the back.
Thanks for your time and any help.
Alicia
