Old 01-29-2021, 06:10 PM #46
DabberAZ DabberAZ is offline
DabberAZ will become famous soon enough DabberAZ will become famous soon enough
Is there no solution to this saga. OP - constant on 12v? Great entertaining read, but no prize at the end. I'm looking for the red switch under the hood that solves this.
2015 SR5 Premium (2019 / 42,335 mi): 1st time 4-Runner owner | 3rd row | N-Fab step / slide | Falken Wildpeaks AT3W 265/70/R17 | Alpicool C30 Fridge / Freezer | Danchel 6.5' x 8.5' awning | ... it's coming along, but still mostly stock still. (mini ipad navigation coming soon)
DabberAZ is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 10:04 PM #47
brockleigh brockleigh is offline
brockleigh is on a distinguished road
Radio and clock but not 12V
I tried Jickos mod today on my 2016 but I didn't have the same results. When I flip my switch the radio and the clock comes on... but not the 12 volts...
Well, the car didn't melt down so... now I can turn the radio on without the key.
Anyone want to take a stab at why it didn"t work?
Originally Posted by jicko View Post
OK (after my coffee and on my drive to work), I figured it out, it's similar but definitely not the same mod.
@Antman 's post: ANTMAN'S Thread - Page 4 - Toyota 4Runner Forum - Largest 4Runner Forum is to use the wire-tap to sneak out 12V constant ON power, and provide that directly to the front cigarette lighter power socket (or any socket); with the flip on the switch, get it back to original factory config.
@Reata 's post: Reata's Build Thread - Page 2 - Toyota 4Runner Forum - Largest 4Runner Forum is to run a wire all the way from the battery to the rear (and even add an "always HOT" cigarette lighter power socket); IMO, this is WAY too much work, IF I don't have to do it (depending on how successful is my suggested mod is)
Now, the mod I suggested in 12v Constant on and/or switched power - Page 2 - Toyota 4Runner Forum - Largest 4Runner Forum allows EVERYTHING that is covered by 15A P/OUTLET fuse to be have constant ON power with the flip of the switch. Unfortunately I do not have the 2014/2015 electrical wiring diagrams, so I cannot confirm (until I actually have time to probe around), what are exactly covered with this particular fuse.
This mod should let me avoid the need to run the front-to-back wire, which I consider "lots of work" if I don't need to do it.
Let me execute on this mod first, if it is as useful as I thought it would be, I may consider putting together a simple plug&play kit group-buy for our members.
PS. does anyone have a list of the "EVERYTHING" cover by the 15A P/OUTLET fuse on 2014/2015?
brockleigh is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 12:20 AM #48
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
The Antman mod to create one dash outlet that switches between constant on and the OEM ignition powered outlet works well. That’s what I did.
Also there’s a mod where all power outlets are powered constantly on. It’s described here, see post #17.
Rear 12v outlet | Toyota 4Runner Forum [4Runners.com]
Old 05-25-2021, 08:27 PM #49
Thanks electroboy, I will try this again, however I feel I have this at the moment but with a switch. i'll update later if the results are the same for anyone else that may experience the same thing.
2016 TE KDSS
Old 05-26-2021, 03:22 PM #50
YEAH BOI!!!!!!! Thanks @ElectroBoy . I made you set up and it works SO...It turns out I had my original setup fuse tap in p/outlet reversed. I assumed I had it the right way because originally I had the fog light mod in p/outlet and it was working (reversed). I now have both mods janked together and they all work. Power to the DC ports and fog lights anytime. 12v constant mod with the switch and antmans foglight mod can live together. However your fog lights will remain ON if you have the DC ports hot and the fog lamp switch on the column engaged.
2016 TE KDSS
Old 08-11-2022, 04:26 PM #51
SuedePflow SuedePflow is offline
SuedePflow is on a distinguished road
Have you or anyone else figured out how to do this on a 2020?
It seems that running a constant 12v to the P/Outlet in the fuse box on a 2020, does NOT work on a 2020 model. I'm hoping someone has figured out the hack for the 20+ cars.
-Paul
'20 TRD ORP
SuedePflow is offline   Reply With QuoteReply With Quote
Switched Power in the overhead Deep_palancar 5th gen T4Rs 5 02-27-2011 05:35 PM
Added power ports to 1992, constant power surfcitylocal Classic T4Rs 4 07-21-2010 10:44 AM
12v switched power source 4runnerman09 4th Gen T4Rs 0 02-05-2010 02:21 PM
Constant 12v outlet - switched ccrios Engines / Suspension / Wheels / Tires / Audio / Accessories 10 11-05-2009 11:17 PM
Easy way to tap 12V switched power? jsarche Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-22-2007 07:47 PM
