When I received my kit of nuts, I did not have enough of the correct size. Recommend you count before you start. Also make sure you have at least 1 jack to assist with holding up the gas tank before you start (recommend the gas tank is near empty
-- Mine was full when I started it was a little much to push up, put the bolt in and use a ratchet!
Charley
2010 Silver SR5 4x4 ShrockWorks Rock Sliders
Blog:
rlinger.wordpress.com
