Old 06-07-2011, 11:15 AM #1
Ukie's Avatar
Ukie Ukie is offline
Ukie is on a distinguished road
Ukie's Avatar
Clear Coat
Something new I've learned while preparing for a detailing of my black 4runner... Black T4Rs do not have a clear coat finish on a paint. It's a 'single stage' or 'flat' paint. Single stage black is generally on the soft side.
Here's an email from Toyota:
We appreciate the opportunity to address your inquiry on the clear coat finish on your 2011 4Runner.
We have checked your Vehicle Identification Number (VIN), xxxxxxxxxxxxx, and determined that your 2011 4Runner does not have a clear coat finish on the vehicle. Only metallic and pearl colors come with a clear coat, and the black paint on your vehicle is flat.
If we can be of further assistance, please feel free to contact us.
Sincerely,
xxxxxx xxxxxxxxxxx
Toyota Customer Experience Center
Ukie is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 11:24 AM #2
chetJ's Avatar
chetJ chetJ is offline
chetJ is on a distinguished road
chetJ's Avatar
By metallic and pearl colors they mean colors like silver? Grey?
What are the implications of this for a black 4R?
2011 Magnetic Grey -Limited
chetJ is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 11:53 AM #3
Ukie's Avatar
Ukie's Avatar
Really none. Just something to keep in mind when you are removing scratches/swirls, polishing, etc - you do not have a clear coat to work on. You are working on a paint so you should not be very aggressive unless there is a reason for that.
Here 'official' T4R color names from Toyota website:
Black
Blizzard Pearl
Classic Silver Metallic
Magnetic Gray Metallic
Salsa Red Pearl
Shoreline Blue Pearl
Looks like Black is the only one without a clear coat.
Old 06-07-2011, 12:46 PM #4
Turn_down's Avatar
Turn_down Turn_down is offline
Turn_down is on a distinguished road
Turn_down's Avatar
Hmmm, maybe that's why the wife actually chipped the paint yesterday when my lift gate hit the garage door. I bet if I had a clear coat, the paint wouldn't have chipped so easily.
Turn_down is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 01:00 PM #5
homeyclaus's Avatar
homeyclaus homeyclaus is offline
homeyclaus is on a distinguished road
homeyclaus's Avatar
Black
Blizzard Pearl
Salsa Red Pearl
Possible conflicting school of thought: With black, you can use more aggressive polishing products to restore the lustre of the paint, because you don't have a clear coat. The paint layer thickness is the same either way, which means you also have a great deal of "depth" to work with.
Clearcoats are very thin, so using anything too much will eventually get through the surface and allow the elements at the pigment layer. Remember that most automotive waxes were abrasive until the 80's, and lot of people ruined their clearcoats using those products. You have no such worry.
Oddly enough, my bright white 04 Matrix had a clear coat.
'13 Spruce Mica Tundra CM 5.7L Trd, EXP1 front bumper, Transforce AT LT275/70R18s, White Knuckle Sliders, Leer 100XL cap w. Wilderness Package, Line-X.
Sorry, I can't help but think less of you when you won't take the time to spell things right or use proper grammar. Deal with it. I don't care if you're ESL either, because I am too.
homeyclaus is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 01:13 PM #6
mountaineer83 mountaineer83 is offline
mountaineer83 is on a distinguished road
This is intresting as I just did a correction on my black 2011. I used a Porter Cable and polishing compounds with outstanding results. However, there was no black residue on the polishing pads as if I were polishing a single stage paint.
2011 SR5 - Black w/Sand Biege leather
2007 Yamaha Rhino 660 SE
mountaineer83 is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 01:39 PM #7
Ukie's Avatar
Ukie's Avatar
Indeed it's interesting. I'm not a pro detailer and based on research I did black residue should be left on a polishing pads if it's a single stage. And it's the best method to test if you have a single stage paint.
Old 06-07-2011, 01:53 PM #8
Ukie's Avatar
Ukie's Avatar
Originally Posted by skel View Post
What are your plans for detailing Ukie?
  1. Clean a car paint using Finish Kare Paint Decontamination System Finish Kare Paint Decontamination System, auto paint cleaning system, de-contamination solution
    --or --
    just by using Finish Kare Soil & Coating Remover/ Wax & Detail Pre-Cleaner (Step 1) and Finish Kare 118 Super Concentrated Shampoo 31 (Step 3)
    --or --
    use a fine clay bar to avoid marring.
  2. Correct some scratches by hand (ScratchX 2.0 or whatever will work).
  3. Collinite 845 wax for the base layer.
  4. Layer of collinite 476S for durability.
It's a plan. Hopefully I'll be working on it in next couple weeks so experience/results to follow.
Thanks for the recipe above goes to Accumulator from autopia - http://www.autopia.org/forum/members/accumulator.html
Old 06-07-2011, 02:27 PM #9
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
I too have removed a scratch (was a bodyman in another life) using 3M Mirror Glaze Heavy Cut Compound. It was a small scratch so I did it by hand. I used a bright green rag and also did not get any black residue. Hmmmm. I followed it up using 3M Swirl remover and then a little wax.
1engineer is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 02:31 PM #10
Turn_down's Avatar
Turn_down's Avatar
I asked Mr. Googlea' (a.k.a. I googled it) and found a thread from a few years back that said all american cars from toyota except white have clear coat. The guy worked for the company that supplied Toyota with the stuff.
I don't know. All I know is I have a chip missing on my lift gate. LOL
Old 06-07-2011, 04:55 PM #11
Johnny Utah's Avatar
Johnny Utah Johnny Utah is offline
Real Name: Matt
Johnny Utah is on a distinguished road
Real Name: Matt
I've got like 5 small chips too. They are probably the size of a couple pin drops(couldn't think of anything else) Maybe a little bigger. Either way pretty small.
I was spraying some of that yellow foam stuff and the excess flew out the window(i was working on the outside of the house) anyway, some very small specs flew out and around the house and landed on top of my 1 week old black SR5.
When pulling the small specs of yellow foam off my car, it pulled the paint too. That was a bad week to be around me.
2011 4Runner SR5 - Black
Stubby Antenna - 5% Tint - Weathertech Liners
Pioneer AVIC z130BT w/Camera feed in Nav
Ultra Gauntlet 20 X 9 - Nitto Terra Grappler G2 275/55r/20
H11 XTREME LED PRO Kit
Johnny Utah is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 05:07 PM #12
Turn_down's Avatar
Turn_down's Avatar
WOw, that pulled the paint off?? WTF?? 30-40K and some foam pulls off the paint?? Geeze. Next year they'll be using shoe polish to paint the cars. LOL
Old 06-07-2011, 07:46 PM #13
homeyclaus's Avatar
homeyclaus's Avatar
Next thing you know brake fluid will take paint off. Oh wait ...
Old 06-08-2011, 09:43 AM #14
kmiller8821's Avatar
kmiller8821 kmiller8821 is offline
Real Name: Ken
kmiller8821 is on a distinguished road
Real Name: Ken
Wow, I would be extremely pissed. Why would foam pull paint off?? That must have been some sticky sh*t or something. Note to self, no foam near truck.
2010 Limited Magnetic Gray Metallic
with Navigation system
kmiller8821 is offline   Reply With QuoteReply With Quote
Old 06-08-2011, 10:50 AM #15
Ukie's Avatar
Ukie's Avatar
Does it look like a stone chip on a hood (e.g. you can see a bare metal)? I hope it's just a paint damage which can be corrected.
black , clear coat , detailing
Clear coat or not ??!! 2003_4Runner 4th Gen T4Rs 31 02-26-2020 02:16 PM
Something ate my clear coat. doclionel 4th Gen T4Rs 6 12-04-2009 01:42 PM
Clear Coat Issue Snookster 3rd gen T4Rs 1 11-25-2007 12:45 PM
Clear coat: definition and problems. tomh Maintenance/Detailing 6 10-14-2004 04:32 PM
Clear coat question lshanahan98 Maintenance/Detailing 6 04-07-2004 02:12 PM
