Thread Tools Rating: Thread Rating: 26 votes, 4.69 average. Display Modes
Old 01-10-2012, 08:40 PM #316
phillyd2's Avatar
phillyd2 phillyd2 is offline
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
I only wish I did not have two left hands when it comes to wiring - lots of nice Anty Mods here I'm just too dumb to try. Dermal the hell out of my truck? Yeah, no problem. Splice one wire? I'm off crying to mama
Nice job as usual brother!
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is offline   Reply With QuoteReply With Quote
Old 01-10-2012, 11:24 PM #317
libido libido is offline
libido is on a distinguished road
Apparently, having a large dildo helps to overcome those kinds of problems. I'm sure that Antman could provide some insight in that regard.....I still cannot for the life of me understand why he needs to include a dildo in his provisions, but then I'm not going to bash someone for their peculiarities.
Cheers,
Greg
libido is offline   Reply With QuoteReply With Quote
Old 01-11-2012, 05:20 PM #318
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
Just wanted to let you guys know, I had to troubleshoot this MOD today.
When the truck was running, things weren't working as planned. The DRL's were getting a ground from 2 sources, and stayed on unless the headlights were on. None of this happened with the ignition in "run" when I tested it. With the truck actually running, things changed...
Everything is sorted out now- had to change the ground setup a 'lil bit. Updated the post above, works perfectly.
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 01-25-2012, 09:58 PM #319
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
Absolute Madness
Well, after 3 days of , brainstorming, troubleshooting, and many pages of this stuff...
-I am finally happy with the DRL/Independent Fog MODS. They are now talking to each other nicely, and working the way they should.
Here's what the final project does:
** DRL's are controlled by the factory switch. They turn off with the switch, and DRL's are on with the parking lights AND the headlights.
** Foglights can be turned on at any time, as long as the ignition is on.
** Whenever the foglights are on, the DRL's are automatically turned off. (Because I don't like the way it looks with both on at the same time...)
** Turn signals work the way they should.
I don't think I am going to post a full writeup on this MOD, because I'm not sure anyone is crazy enough, or cares enough to do it. If you do plan on doing this, you need to complete the Independent Fog MOD first.
I had to do it because after several failed attempts to make all of the above conditions work, I felt defeated. No way Mr 4Runner(NM156) was winning this one.
Basically, the DRL's are turned on by grounding this green wire.
ANTMAN'S Thread-370-jpg
The factory wiring provides this ground when the switch is set to "DRL", or "Parking Light" only. If you ground the green wire with a jumper, the DRL's can't be turned off with the factory switch. I got around that by only applying an extra ground (via relay) when the taillights are on(meaning the head, and or parking lights are on). To make the DRL's turn off when the fogs are on, the entire circuit is cut (again via relay). This same circuit is normally closed (via, um...relay) to allow the DRL's to function when the switch is set to "DRL". Now you know why it took me a few days. Yes, it is confusing!
To make all this stuff work (at once) requires 3 separate relays, 13(!) different connections, and alot of patience to make the wiring look neat and clean. But, it's done. It works perfectly, and I win... That said...
I am planning on drawing up a wiring diagram(no way you can figure out the one above- it's written in Antman ) and posting it soon. I'll snap a few pics of the area where the relays are mounted up as well.
I'm a geek, I know.
Happy Modding guys!
EDIT- Wiring diagram here, and a few posts down as well...
ANTMAN'S Thread-dscf0925-jpg
Old 01-25-2012, 10:15 PM #320
tlflow's Avatar
tlflow tlflow is offline
tlflow is on a distinguished road
tlflow's Avatar
Dang!
maybe now you will have time to work on cold fusion, I here they need some help!
2010 Trail Runner, KDSS;
Overland Warehouse 2.5 HD Kit - tuned to tow, Camburg UCA, 285-70/17 BFG KM2, Gobi Stealth, SW Sliders, SW Bumper, WARN 9.5xp, ProComp 7028 17X8.5/4.75 BS ...
tlflow is offline   Reply With QuoteReply With Quote
Old 01-25-2012, 10:37 PM #321
knc1us69's Avatar
knc1us69 knc1us69 is offline
knc1us69 is on a distinguished road
knc1us69's Avatar
H2O Mod
I know you pm'd me already but remind me how you run your 4Runner on water only again?
knc1us69 is offline   Reply With QuoteReply With Quote
Old 01-25-2012, 11:44 PM #322
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
HaHaHa! You used graph paper! Well on your way. I bet night classes are in your future! Wait until Calc I, II and III and DiffEq. You'll love it!
1engineer is offline   Reply With QuoteReply With Quote
Old 01-26-2012, 10:22 AM #323
4Run4YourLife 4Run4YourLife is offline
4Run4YourLife is on a distinguished road
Cal I, II, III & DiffEq were no problem. It was Dynamics that was the killer for me.
4Run4YourLife is offline   Reply With QuoteReply With Quote
Old 01-27-2012, 01:01 PM #324
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
As promised- The wiring diagram for this madness...
Old 01-27-2012, 01:16 PM #325
marcgybr's Avatar
marcgybr marcgybr is offline
Real Name: marc
marcgybr is on a distinguished road
marcgybr's Avatar
Real Name: marc
Thumbs up
We all know who passed circuits class with flying colors.
'10 LE
>instagram<
marcgybr is offline   Reply With QuoteReply With Quote
Old 01-27-2012, 01:22 PM #326
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
He he- I had "electronics" In 1986 in HS- other than that I just learned from various projects/friends over the years.
Old 01-27-2012, 01:32 PM #327
phillyd2's Avatar
Real Name: Dave
phillyd2's Avatar
Real Name: Dave
After seeing him hunched over drawing on graph paper for hours and then take a picture to post on the internet I'm thinking his wife just wishes he downloaded porn like everybody else.
Old 01-27-2012, 01:54 PM #328
DizzyV6P DizzyV6P is offline
DizzyV6P is on a distinguished road
Wow. But you left out the flux capacitor that's needed to do the time travel thing in addition to controlling the fogs. ;)
2011 Toyota 4Runner Limited (White Blizzard Pearl) w/ Nav, 15 speaker JBL, Rosen av7500 dual headreset dvd players, OEM running boards, Pursuit Extended Range Remote Start and bug deflector.
DizzyV6P is offline   Reply With QuoteReply With Quote
Old 01-27-2012, 02:06 PM #329
Theslammer21's Avatar
Theslammer21 Theslammer21 is offline
Theslammer21 is on a distinguished road
antman, you are awesome. save all of us the headache of going through the wire diagrams piecing it together. i work at lexus, fully capable of figuring it out and have access to all the wiring diagrams but you break everything down well and save us the trouble. very much appreciate what you do.
btw. did the back up camera mod last night, thanks again
Theslammer21 is offline   Reply With QuoteReply With Quote
Old 01-27-2012, 02:12 PM #330
i initially relayed my fog lights off of my corner lights due to laziness which was nice because it gave me fogs without or with DRL control but i really wanted tail lights with fogs. i think you provided my new wiring setup
Thread of LOL Opi Off Topic 5 05-19-2011 12:59 PM
Another would you do it again thread ..... Falls 4th Gen T4Rs 21 01-03-2008 10:14 PM
Last Thread... It's between two... rmd0311 4th Gen T4Rs 4 10-13-2006 06:32 PM
Hi all!!!! first thread 4me here! bolt 4th Gen T4Rs 2 04-11-2006 12:49 AM
