Thread Tools Rating: Thread Rating: 26 votes, 4.69 average. Display Modes
Old 06-28-2011, 09:41 AM #31
kmiller8821's Avatar
kmiller8821 kmiller8821 is offline
Real Name: Ken
kmiller8821 is on a distinguished road
Real Name: Ken
Very nice Antman! I'm with you tho, that LED not coming on would drive my OCD self crazy. lol.
2010 Limited Magnetic Gray Metallic
with Navigation system
kmiller8821 is offline   Reply With QuoteReply With Quote
Old 06-28-2011, 10:15 AM #32
Turn_down's Avatar
Turn_down Turn_down is offline
Turn_down is on a distinguished road
Turn_down's Avatar
Without the LED, how would you know they were on??
LOL Joking of course.
Turn_down is offline   Reply With QuoteReply With Quote
Old 06-28-2011, 10:49 AM #33
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
ANTMAN MOD #4.1
Lighting up the FOG indicator from the FOG MOD
Well, it took all of 24 hrs, and the "Fog LED not lighting up" thing bugged me enough to do something about it. I took the dash apart -again- and buried an LED in there behind the FOG indicator. I used an orange LED, mostly because I didn't have any green available, and the electronics store is 30 mins away. What do you guys think about it? I'm not sure yet, may just throw a green one in there since all the real work is done for this...
The entire dash comes apart without any tools, except for a phillips screwdriver- thanks Toyota!
Here's what you need to pull off:
*The plastic panel where your fan switch is located
*The panel to the right of the steering column that houses the useless "party mode" button
*The panel to the left of the steering column that has your mirror controls
All of these panels pull towards you- use your muscles!- to come off
The steering column screws, under the steering wheel, need to come off and then you can pull the black plastic guage surround off. it's connected to the top of the steering column plastic with a piece of vinyl.
4 screws remove the cluster, and the plug is on top. Here's what you end up with...
ANTMAN'S Thread-001-jpg
ANTMAN'S Thread-002-jpg
ANTMAN'S Thread-003-jpg
The top of the cluster has molded in black plastic tabs holding it on. Simply take a small screwdriver and- patiently- work your way around the cluster to remove it.
ANTMAN'S Thread-005-jpg
Remember this- every time you look at your dash you will notice any dirt, dust, or fingerprints you get in here! Be careful...
ANTMAN'S Thread-004-jpg
I used a hobby knife to cut a slot for the LED , and it's wires. You can't access this area without removing the needles for the guages, so this was the only way to get it in there! I cleaned up this cut significantly, before I was done- forgot to take a picture...
ANTMAN'S Thread-006-jpg
Here's a LINK on how to make LED's like this one that's buried in the slot. Note: The long black push-button that goes through the hole in the guage face pulls right off, and snaps back in easily. This made the job alot easeir once I figured that out
ANTMAN'S Thread-008-jpg
I messed around with the positioning of the LED, to try to get the lighting as even as possible.
Now everything can go back together. The ground to the LED gets connected to the ground in the FOG MOD writeup, and the hot-lead ties into relay terminal#30.
Here is the result, whenever the fogs are on...
ANTMAN'S Thread-010-jpg
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 06-28-2011, 10:56 AM #34
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
WoW impressive!
1engineer is offline   Reply With QuoteReply With Quote
Old 06-28-2011, 11:07 AM #35
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
Originally Posted by 1engineer View Post
Very nice write up and mod! Since you can't trick the computer into lighting up the dash how about just tying a LED into the fog light power circuit and positioning it behind the dash fog light icon?
Well, I only did it because of your constant nagging about burying an LED in there...
Old 06-28-2011, 11:19 AM #36
Real Name: Ken
Real Name: Ken
Very cool. I wonder how many warranties you've voided so far! j/k. Looks great. (I know you will end up getting the green LED, it's driving you crazy already isn't it?) ;)
Old 06-28-2011, 11:34 AM #37
Turn_down's Avatar
Turn_down's Avatar
Although I'll never ever ever do a quarter of the mods you've done, you, sir, are an inspiration. Very impressed to say the least.
It's going to break your heart when you sell this thing in the future. lol
Old 06-28-2011, 11:36 AM #38
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
... don't ... like ... orange ... must ... do ... green ...
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 06-28-2011, 11:47 AM #39
Johnny Utah's Avatar
Johnny Utah Johnny Utah is offline
Real Name: Matt
Johnny Utah is on a distinguished road
Real Name: Matt
holy ****! You sir are a bad..bad man!
i'd go with Blue LED. that would stand out
2011 4Runner SR5 - Black
Stubby Antenna - 5% Tint - Weathertech Liners
Pioneer AVIC z130BT w/Camera feed in Nav
Ultra Gauntlet 20 X 9 - Nitto Terra Grappler G2 275/55r/20
H11 XTREME LED PRO Kit
Johnny Utah is offline   Reply With QuoteReply With Quote
Old 06-28-2011, 12:52 PM #40
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
...damn you both...
Old 06-28-2011, 12:56 PM #41
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
...naaah. You should have seen my GTI. THAT broke my heart to sell!
Plus I think I'll keep this one awhile. I kinda like it
Old 06-28-2011, 01:10 PM #42
Turn_down's Avatar
Turn_down's Avatar
PM me some pics. I, too, came from a VW only household. Actually, my wife still has hers, and still wants a Vdub for her new car.
Old 06-28-2011, 01:54 PM #43
Antman's Avatar
Real Name: Jeff
Antman's Avatar
Real Name: Jeff
Ummm- just got back from Baynesville Electronics. Green LED in hand...
Pretty soon this dash will take itself apart!
Old 06-28-2011, 02:27 PM #44
Real Name: Matt
Real Name: Matt
Let the record show that i am officially nominating Antman for T4R.org Member of the month, for his crazy LED/fog light mod!
Old 06-28-2011, 03:07 PM #45
Turn_down's Avatar
Turn_down's Avatar
I'll second that, but not for the mod. For the fact this is his third time taking his dash apart!
Thread of LOL Opi Off Topic 5 05-19-2011 12:59 PM
Another would you do it again thread ..... Falls 4th Gen T4Rs 21 01-03-2008 10:14 PM
Last Thread... It's between two... rmd0311 4th Gen T4Rs 4 10-13-2006 06:32 PM
Hi all!!!! first thread 4me here! bolt 4th Gen T4Rs 2 04-11-2006 12:49 AM
