Originally Posted by Antman
To answer your questions:
1- The amber lights are the turn signal- DRL. They won't light up with the parking brake depressed. Check that...
2- You can light the original green LED by grounding the brown wire- BUT- it only works when the fogs are on with the headlights. In other words it works the way it did before the mod. Your fogs will still work whenever you want.
I was hoping someone could figure it out, but so far no luck!
Glad you like the mod- Independent Foggers unite!
Thread to the top! I did the foglight mod. Thanks for figuring it out. Years ago I figured out how to do it on my 06 Tundra by just cutting a wire and splicing into a powered wire, no relays or nothing. But I did this one without understanding the logic, but it works.
HOWEVER I tried #2; grounding the brown wire from the plug. It does light up the green LED as you say, BUT the fogs are ALWAYS on with low-beams then. I undid that part. I'm just going to try to forget the green LED ever existed...there isn't one on my Tundra either.
thanks,
Joe
