Originally Posted by alvorbn
The other factoid I left out is that my fridge has been out of the truck for a couple of days and the a/c is still delayed. Will the battery recover or is it time to look into a different setup? The fridge is the smallest one ARB makes and was supposed to be ok for a single battery setup. Maybe it's time to get a proper 'manly' battery.
If your battery is significantly discharged it could take a while to charge back up under normal driving conditions- especially if you are still putting a considerable load on the electrical system. You may want to take a short trip to charge it back up-
What is your "soft- wired" radar detector? Maybe you have a constant drain on the battery when the vehicle is off? Even a small load adds up over time to drain the battery!
