Originally Posted by eks44
Did any one ever find a solution to this problem? My 2001 is having the same problem - the other doors lock/unlock and alarm with the keyless entry or with the door switch, but the driver's side will only lock/unlock if lowered/raised manually. It looks like some similar problems were solved by replacing a fuse. Is this a similar situation, or does the door panel have to be removed?
I have the same problem, I bought a new door lock actuator but its gonna be a PITA to install so I'll probably procrastinate on doing it for a while.
2002 SR5 4x4- Resurrection in Process
Originally Posted by t4r4life
i like how my nipples are all smooth and pointy all six of them, sometimes i rub them when they get dirty
