Old 09-20-2020, 12:40 PM #106
Srsd2850's Avatar
Srsd2850 Srsd2850 is online now
Srsd2850 is on a distinguished road
Srsd2850's Avatar
I would like to see the present engine get a dial with different driving modes and an ETC button. A good throttle controller makes the 5th gen feel like it has a new engine, why not give us this kind of capability built in from the factory? I had two vehicles with 8 speed transmissions and hated it. I specifically went to a new 4Runner to get away from that stuff. A 6 spd would be ok. Also, Iím not interested in buying the first year or two after release of a new and unproven engine.
- Mike
2018 4Runner SR5P 4x4, Nautical Blue
General Grabber ATX P265/70R17, TRD 17 Matte Black Alloy Wheels, Weather Tech Hood & Side Window Deflectors, Blackout Emblem Overlays
Baja Designs Squadron SAE Amber Fog Lights
Srsd2850 is online now   Reply With QuoteReply With Quote
Old 09-21-2020, 12:11 PM #107
Bikeric's Avatar
Bikeric Bikeric is offline
Real Name: Eric
Bikeric is on a distinguished road
Bikeric's Avatar
Real Name: Eric
Originally Posted by Jetboy View Post
No one is immune. But all of that was on the SAME one truck. In the case of the front diff - it had never had oil in it ever. So it was shipped from GM with no gear oil. That's the sort of quality control problem that plagues GM. And poor engineering. A crank position sensor inside the bell housing? There's no reason that should ever exist. And if it does, it should at least be accessible from the bottom, not the top. It requires removing the cab to access in the FSM. Not once have I ever seen any Toyota product with that type of shortcut in engineering. Toyota's BOF are way out of date. I'm fully in agreement with that. But they were properly engineered to begin with.
I guess you've never had a starter go out on a 4.7 V8? Step 1: Remove intake manifold.....
1997 Limited 2wd, 2003 Sport V8 4wd
Bikeric is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 03:24 PM #108
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future
Jetboy's Avatar
It's not ideal for sure - but it may actually be easier than some engine mounted starters that are very hard to access. Taking off the intake manifold on my 3.4 was about 45 minutes. Not fast- but actually pretty easy to do. Also GM already does that - or at least some GM v8's are done that way. At least on the Toyota version you're not also opening up cooling passages so you don't have to drain the coolant system first - and inevitably pour some coolant down the intake ports.
I don't think it really compares to some GM stuff though. Imagine that starter being inside the bell housing on top of the rear of the engine. For example GM's new I6 diesel. It has a belt driven oil pump that requires replacements at 150k. Okay - timing belts are easy enough. But wait - it's ON THE BACK OF THE ENGINE! And it cannot be removed without at a minimum removing the flex plate to fit the belt around the drive teeth on the crank shaft output. So you either get to remove the engine up through the hood - or more likely remove the transmission/transfer case at 150k on every one of them. Why would GM ever do that? Why would anyone ever do that?
What is that going to cost? $2500 for a belt replacement at 150k miles?
Old 09-21-2020, 04:17 PM #109
mscot mscot is offline
mscot has a spectacular aura about mscot has a spectacular aura about
B/c GM knows their vehicles wind up in junkyards long before they ever reach 150k miles.
TRD Off Road Prem w/ KDSS: XD Series Turbine wheels, Falken Wildpeak 285/70s, Eibach Pro-Truck Suspension, RCI 5-degree sliders, Sprint Boost, C4 Fab Lo Pro bumper w/ winch and lights, LFD Offroad 7/8 Rack, custom rear drawer system, some black stuff here and there
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 05:18 PM #110
Jetboy's Avatar
Jetboy's Avatar
It's disappointing. I really want that new I6 duramax to be great. The idea is just what I'd want in a mid size SUV. the little 180hp 4cyl turbo diesels are not enough for a 4Runner size SUV in the USA. But an I6 with 280hp diesel - that would be the goldilocks engine. And probably exceed 30mpg in a 4Runner size SUV. And GM started with a clean slate design. There's just no reason for it. A simple gear drive pump could work great. Or a shaft drive pump with a belt that you can access from a side panel? Or any of the traditional oil pump options. Even an electric one would be better.
Old 09-22-2020, 07:32 PM #111
My TDI Touareg got mid to high 20s around town and in the 30s on long interstate trips. I really miss that engine.
The 4Runner has been quite a downgrade.
Build thread
Old 09-23-2020, 10:21 AM #112
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R has a spectacular aura about NW.OH.T4R has a spectacular aura about
Real Name: Jason
I really like the TDI Touregs. I wanted to move into a 3.0TDI Q5 from my S4, but there wasn't enough space in the backseat. The older gen Q7 TDI is just okay, but can look good with an aggressive wheel offset and all-terrains. The 3.0TDI is one of the more reliable VAG engines of recent history.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 09:41 AM #113
leprechaun311 leprechaun311 is offline
leprechaun311 is on a distinguished road
Originally Posted by Daddycreswell View Post
I'm also waiting/ready for the new Bronco...
Going to park it right next to it's great grand father.
Sent from my SM-N960U using Tapatalk
Love it. Hereís mine
Sent from my iPhone using Tapatalk Pro
leprechaun311 is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 12:01 PM #114
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a jewel in the rough RichinRidgewood is a jewel in the rough RichinRidgewood is a jewel in the rough RichinRidgewood is a jewel in the rough
I cannot imagine the justification they used in the engineering design reviews to sell this crap-tastic "feature". That's assuming GM still even has design reviews.
One stone gets stuck between the belt and the pulley that are down low and boom new engine time.
2 gears and a shaft or even a chain and 2 gears inside the sump ... wtf is wrong with doing it like that?
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 01:35 PM #115
Jetboy's Avatar
Jetboy's Avatar
I think that the assembly is fully enclosed in the oil pan or the bell housing. So probably not prone to a rock - but definitely going to be washed in dirt/mud that gets in there. . But yeah - the choice to directly drive it off the crank shaft means that you have no choice but to separate the transmission to remove the belt or install a new one. That sucks. Even a belt drive off a secondary gear on the side would have made it replaceable without a ton of effort.
The choice to put on the rear I think has to do with vibration dampening. The closer it is to the flywheel the less effect it has on causing vibrations due to flex in the crank shaft. I'd guess it's a very very minor difference if it's measurable at all. But that's my best guess on why you might do that. I can't think of any other reason why you'd even try to make one fit on the back instead of the front.
Old 09-27-2020, 04:44 PM #116
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss has a spectacular aura about rdruss has a spectacular aura about
rdruss's Avatar
Real Name: Ron
Don't be surprised if Toyota brings a Hybrid and/or EV for the new 4Runner.
Old Yesterday, 12:43 PM #117
CO-Cygnus's Avatar
CO-Cygnus CO-Cygnus is offline
CO-Cygnus will become famous soon enough CO-Cygnus will become famous soon enough
CO-Cygnus's Avatar
Bring it.
CO-Cygnus is offline   Reply With QuoteReply With Quote
6th , coming , generation , shocked , ways
HTML code is Off
96 4Runner SR5 white smoke coming from exhaust, black soot/liquid coming out, stalls beefsix Problems & Warranty Issues 7 05-24-2018 03:44 PM
Second generation Tacoma CV axles vs 4th generation 4 runner CV axle mrwinkle13 4th Gen T4Rs 0 10-15-2015 06:02 AM
smell coming and lots of heat coming from manual shifter compartment desertrover Problems & Warranty Issues 0 10-18-2010 08:07 PM
SUpport for USA World Cup 2018 or 2022 JAC Off Topic 0 06-28-2010 11:01 AM
3rd Generation Article/The Best Generation dale 3rd gen T4Rs 5 12-29-2009 04:46 PM
