Old 08-13-2020, 11:45 PM #1
ClarkDalton ClarkDalton is offline
ClarkDalton is on a distinguished road
Water leaking form under dash.
Hey,
I have rain water leaking into the driver side floor from under the dash. Im not sure if some type of drain is backed up or the what. Any ideas?
ClarkDalton is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 12:28 AM #2
Baystate4Runner's Avatar
Baystate4Runner Baystate4Runner is offline
Baystate4Runner will become famous soon enough Baystate4Runner will become famous soon enough
You will get more answers if you post this in the correct forum - depending what generation / year your 4Runner is.
The 6th Generation section is definitely the wrong place as the 6th Gen 4Runner doesnít exist yet. ;)
2021 TRD Pro - Lunar Rock - June 2021 delivery
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W
2012 Porsche Cayman S
Baystate4Runner is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 08:57 PM #3
nimby's Avatar
nimby nimby is offline
nimby has a spectacular aura about nimby has a spectacular aura about nimby has a spectacular aura about
nimby's Avatar
What!?!?!?!?!?!?!?
The 6th gen has a water leak and it's not even out yet?
Will not buy.
I'm sticking with my diesel, manual trans, locking hub, straight axel.
nimby is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 04:27 AM #4
makeitso2008 makeitso2008 is offline
makeitso2008 is on a distinguished road
probably the moon roof leaking down?
makeitso2008 is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 09:21 AM #5
Heffernan's Avatar
Heffernan Heffernan is offline
Real Name: Ryan
Heffernan will become famous soon enough
Heffernan's Avatar
Real Name: Ryan
You have a blockage in one of your sunroof drains.
Same thing happened in my 4th gen.
It's leaking down the A-pillar and coming out under the dash. Check your drains.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 10:07 PM #6
ravenxm ravenxm is offline
ravenxm is on a distinguished road
open the sunroof blow thru drains
ravenxm is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 12:22 AM #7
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec has a spectacular aura about rigtec has a spectacular aura about rigtec has a spectacular aura about
rigtec's Avatar
Real Name: Greg
Hi makeitso2008,
Most def! Could be the Moon-roof drain(s); they run through the "A" pillars, but then the tube SHOULD go Straight Out to the ground... I'd get a good light up there and look for water stains to locate the source; sounds like a drain tube got cut or disconnected! 'Best to you',
rig, cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 07:44 PM #8
mrblah mrblah is offline
mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of
those pesky 6th gens.............
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
Old 10-12-2020, 06:17 PM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
100% of all 6th gen 4Runners sold to date have massive leaks onto the floor boards, literally every 6th gen that has been sold and delivered to the public to date is just driving around with sloshing water
jhguth is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 08:29 PM #10
FD7683 FD7683 is offline
FD7683 will become famous soon enough
6th gen 4Runner has a water leak.... yet hasn't came out to the public yet. What a POS.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
Old 03-18-2021, 06:27 PM #11
Nick Nostril Nick Nostril is offline
Nick Nostril is on a distinguished road
My 2046 7th gen 6WD has the same problem.
Otherwise, as others have said, blow out your moonroof drains, or pray to Buddha it's not your heater core ($$$).
'21 MGM ORP. Husky mats, No-name crossbars and dashcam. Much more to come.
Nick Nostril is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 07:10 AM #12
StanleyMWhite StanleyMWhite is offline
StanleyMWhite is on a distinguished road
Re: Water leaking form under dash
It may be caused due to the blockage in the drain. You should check the drain.
StanleyMWhite is offline   Reply With QuoteReply With Quote
backed , dash , drain , leaking , water
HTML code is Off
Leaking water under the dash area Stormtrooper52 5th gen T4Rs 21 04-25-2021 04:31 PM
water leaking in jpeak 5th gen T4Rs 3 01-02-2019 07:30 PM
Water leaking manp0899 Problems & Warranty Issues 1 02-16-2010 12:27 AM
Water leaking from AC? Avet14 4th Gen T4Rs 4 06-23-2008 10:38 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
