05-02-2024, 02:18 PM
#241
Originally Posted by Jetboy
For me the 4Runner sits half way between the Bronco/Wrangler and Jeep GC. Toyota doesn't build a direct competitor in either of those two segments. Nor does Jeep or Ford sell a 4Runner competitor in the USA market. Ford does build and sell the Everest that is pretty similar to a 4Runner segment globally. But not in the USA. I don't think anything globally in the Jeep world is similar. In my view the closest direct competitor to the Wrangler in the toyota corporate umbrella is the Subaru outback. It's very similar structurally.
Anyway - 4Runner overlaps the jeep/bronco market. I think this moves the needle that way with 35's fitting stock and 37's being pretty easy to bolt on.
I do think Toyota is missing the "fun" part of the market without any removeable top. That's what really separates the Bronco and Wrangler from all others.
I also think the 4R will out perform the Bronco offroad in some conditions. The rear suspension is significantly superior on the 4Runner. The coilover design on the Bronco is a real bummer. It effectively eliminates the benefit of a solid axle while keeping most of the negatives. To maximize the benefits of a solid axle the springs need to be inboard and shocks ideally put outboard as far as possible. Toyota's rear axle coil design is better. Wrangler is also similar to the Toyota design. I think a 4Runner with 37s will be pretty comparable to the Bronco or Wrangler on the trails overall.
A Grand Cherokee Trailhawk is as good or even better than a 4Runner offroad. The Grand Cherokee Traihawk doesn't have a solid rear axle, but it has standard air suspension that gives it a big advantage.
2004 Sport 4x4 Galactic Gray
05-02-2024, 03:40 PM
#242
The 4R sits roughly half way between the Wrangler and GC. On Toyota's side - the GA-L and Subaru products are pretty close to the GC. If you put an SUV body on a Lexus IS350 - it would be a direct competitor with the GC. They are remarkably similar in design from suspension to engine/trans layouts etc. And - IMO - Toyota really should be building a GA-L based SUV that competes directly with the GC. It should be a Lexus GX unibody SUV that is based on the IS350/LS platform with a longitudinal powertrain. And the Lexus TX should also be on that platform, not the extended FWD platform.
As far as better off-road, I think it depends a lot on what you mean by that.
Put both on a starting line in a Baja 1000 or a Mint 400 - 4Runner would be about a 10:1 favorite I think. Maybe more. Start both at the gate keeper to the Rubicon and put bets on which one will come out the other side. I think the same would hold. The last time Jeep tried I think it came out the other end and left on a flatbed to the crusher with every door sill crushed and the transmission punctured.
Take them to a single large round rock - GC might have an advantage in clearance. Maybe even on a sand dune or muddy area. Maybe some Moab trails where the high ride height might help. There's definitely some places a GC will do better. It just depends on whether an extra inch or two of belly clearance matters or whether it needs to be able to handle the abuse of sliding and dragging over rocks and logs. The GC is a car with big tires at its core, so the truck robustness isn't there. But for single obstacles, it can do really well.
Just for fun:
Lexus IS350 suspension vs Jeep GC - they're remarkably similar:
05-03-2024, 12:25 AM
#243
The GC trailhawk would be fun for occasional sightseeing offroading (while the air suspension holds up at least).
A 100-mile stretch at some speed in the desert...is a whole different type of offroading.
Of course, the 4R cannot match a prerunner on that but it can do anything that can be considered somewhat safe for a vehicle without a cage...again, and again, and then again.
So horses for courses.
Though the 4R is best at nothing, it is a faithful Swiss knife and a true offroader meaning it is built so it can take the punishment over a long period of time, not just too look good and do a tough trail once in a blue moon.
05-03-2024, 12:43 PM
#244
I think this hits the nail on the head. I looked at a 4xe Trailhawk last year as an option to replace my Land Rover Discovery Sport (where I ultimately went with my EV).
I felt like the JGC could probably get through most light to moderate offroading situations and probably do pretty well on certain types of more advanced trails also. The air suspension is indeed really good on clearance, but if you look into some more info on this vehicle from Youtubers and what not, I imagine the RTI is definitely lower than that of a 4Runner. The chasis just inherently doesn't flex very well; JGCs seem to lift tires in harder offroading conditions constantly. This isn't neccessarily inherently a huge problem (God knows the Defender does the same thing), but I'd rather keep my rubber on the ground if possible.
Another big Achilles' heel of the JGC are the 31" tires. Additionally, you do not have enough clearance to go much larger. Personally I really don't want to be doing any significant offroading on less than a 32" (and honestly look forward to being able to run a 33" plus with minimal shenanigans on an updated TNGA-F vehicle). I know I could run 33" on my 4Runner easily enough, but don't want to take the performance hit since the power train is already a dog.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
05-03-2024, 02:31 PM
#245
Any pre-released pricing yet for the 6th Gen?
I've heard rumors but haven't seen any real published pricing for the new 6th Gen...anybody else heard anything or just ranges of pricing?
Thanks!
05-03-2024, 06:59 PM
#246
Nothing official out there; your best bet is to look at what a similarly equipped Tacoma is stickered at and add a little bit on.
I imagine Toyota will not release pricing much before at least September to October at the earliest. If this vehicle rolls out as late into 2025 as the Land Cruiser and GX550 are this year, pricing may not even be available until several months into 2025.
Reason: typo
05-04-2024, 12:53 PM
#247
Wonder if 6th gen 4runner will have filter houing cap like the current cap. That is pain in ass to change filters.
05-06-2024, 11:56 AM
#248
Originally Posted by TexasFunRunner
What scenarios caused the FJ Cruiser to rollover, other than idiots driving too fast?
I don't know. My guess? Idiots driving too fast.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
05-07-2024, 04:43 PM
#250
yeah my buddies brand new Braptor had a leaky roof plus you get the bonus of wind noise. No thanks for me
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
05-07-2024, 11:36 PM
#251
Bronco definitely is a favorite of mine, but I don't own one (yet) and gotta say, atrocious wind noise is BIG fact about it on 4 doors. I can't believe that Webasto or whoever is responsible for those tops, screwed the pooch and are allowed to still do this 3 years later.
Chrysler (aka American Stellantis) gets it down right, where I never experience obnoxious exterior noise in the Gladiator and Wrangler. Bronco, sadly not the case whatsoever. Ford would've done well to facelift the Bronco this year and fix these issues. They don't seem serious whatsoever or maybe delayed any such plans, because of the Ranger rollout and/or UAW strike.
05-09-2024, 08:47 AM
#252
Hi
@ Carmaker1
, why did you change your username to
@ GFORCEX
Ford is clueless, sure Webasto is the supplier, but Ford is responsible for managing the design and their suppliers, both of which they fail miserably in.
Ford does not give a ratsass about quality, all they care about is pumping out the numbers, letting the dealers fix the problems, when you can get an appointment, as they are overbooked fixing all the factory screwups.
Yet their golden boy CEO stays on, what a joke.
#253
So....after a month of hard thought I realized I just do not want that new 6th Gen so found a new '24 Limited in Wind Chill Pearl and brought it home last week.
I would have gone for the Limited '25, and I do like the exterior of that model, based on the videos/photos. I can say I am not a fan of some of the other trim line exteriors though.
I just can't get how 'bad' the interior of the new '25 is! They make it look so cheap, IMO. Who wants a giant 'TOYOTA' advertisement on the passenger dash?!?! That is worse than the people who put their make/model on their WS tint strip! It just looks to plastic and cheap, again, just my opinion.
I will say, after about a week with the new '24 I am beyond happy! I held off because I did not think the tech was 'up-to-date' enough, and I was wrong. This thing has so many options, settings, features, etc.
This is coming from someone who bought one of the first 5th Generations in the Northeast - I put a deposit down on it weeks before it arrived at the dealership and when it did it was the only one within 200 miles. I took it for a spin and signed the papers. I looked at the photos/videos and knew it was the vehicle for me.....the same way I looked at the photos/videos of the '25 and know that is NOT the vehicle for me anymore.
Hopefully Toyota will make the '25 a bit more refined, especially the Limited, for those of us who want a nice interior but still want to be able to do a bit of adventuring now and then.
Being a new Generation I think the 1st, and maybe 2nd year, sales will be strong, but I have a feeling they will fall off quickly after that.
I am curious to see what it looks like after year 3 compared to how the 5th Gen sold....time will tell.
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
05-09-2024, 08:56 PM
#254
Fords are total and complete pieces of shit.
05-10-2024, 04:02 AM
#255
Real Name: Jay
Real Name: Jay
I think the market will reign in Toyota's wild pricing on them. A Ranger Raptor is only $58k. Street pricing on the Ranger Raptor is more like $54k advertised, probably $50-52 negotiated price. I think it may be better than the Taco TRD Pro. A ZR2 Bison edition has 35s, double lockers, OEM winch installed, armor, - probably $10k+ on top of a TRD Pro trim and the street price I see on those is $65k. I see Toyota losing a lot of market share by over-pricing the new products into a recession. Or in the alternative pricing will need to be slashed to get things back to reality. I think a lot of buyers will take a Ranger Raptor and two dirt bikes in the back over a TRD Pro Tacoma.
As a data point to compare - a GR Sport LC300 (front and rear lockers, twin turbo v6, eKDSS, 4.10 diffs) is currently priced for export in Japan at $72k, MSRP is closer to $50k used. Part of that is the collapse of the Yen. But the original release of the GR Sport LC30 in 2021 was $76k USD. And that's the halo offroad lux model.
A Tacoma TRD Pro should be around $55k. And I think the market will settle on a price in that range for actual transactions.
Yeah. I just can't imagine sales will remain robust on Toyota SUVs at these price points. Same thing with the pricing on the new GX550.
2000 Honda Civic SI (EM1) Electron Blue Pearl - original owner, 242,300k and completely stock.
2023 Lexus GX460 Premium in Nightfall Mica. 1,450 miles.
HTML code is Off
