Old 04-09-2024, 11:00 AM #1
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Arrow 6th Gen Released by Forbes - ope!
Copy of the article that was momentarily posted by Forbes and promptly taken down. If anyone wants to read up before the launch tonight!
The 4Runner has been a staple of the Toyota lineup for more than four decades and the new 2025 model completes the brand’s complete revamp of its body-on-frame lineup. Starting with the Tundra full-size pickup in 2022, Toyota has leveraged its TNGA-F architecture to launch redesigned versions of the Sequoia, Tacoma, Land Cruiser and Lexus GX and LX. The sixth-generation 2025 4Runner rounds out the family at least for North America.
The original 4Runner debuted in 1983 based off the HiLux pickup. Like most pickup-derived SUVs of the time it featured a removable rear top section allowing it to be used like a half-open pickup with no rear wall and an extra row of seats. That architecture disappeared with the second-generation and starting with the third-generation 4Runner, it began sharing its platform with the Land Cruiser Prado. That relationship continues to this day and expands to all of Toyota’s body-on-frame models. The latest Land Cruiser and Lexus GX are effectively the Prado that is sold in other markets.
Despite having debuted way back in 2009, the current fifth-generation 4Runner remains a surprisingly strong seller. Over the years most of the mainstream branded, midsize, off-road oriented two-row SUVs have fallen by the wayside such as the Nissan XTerra and Chevy S-10 Blazer, leaving the Jeep Wrangler and Ford Bronco as the main competition to the 4Runner.
Like prior 4Runners, the new model also shares a lot with the latest Tacoma midsize pickup including the powertrains. Toyota’s increasingly ubiquitous 2.4-liter turbocharged four-cylinder will be under the hood of all sixth-generation 4Runners. The standard i-Force version delivers 278-hp and lb-ft of torque. The hybrid i-Force Max adds an electric motor and 1.87-kWh nickel-metal hydride battery for a total of 326-hp and 465 lb-ft of torque. Towing capability grows from 5,000-lbs to 6,000-lbs.
Both options come with the same eight-speed automatic transmission found in the Tacoma and Land Cruiser. As before, customers can choose a rear-wheel-drive, part-time four-wheel-drive or full-time four-wheel-drive system. Both 4WD systems have a two-speed transfer case and Toyota’s active traction control system to aid in sending torque to the wheels with the most grip. All variants get an automatic limited slip differential.
The TRD Off-Road, TRD Pro and the new Trailhunter version also get an electronic locking rear differential. The Platinum trim also gets a locking center differential that is optional on the Limited. New to the 4Runner is a front stabilizer bar disconnect that allows for improved articulation of the front wheels over rough terrain.
The wheelbase of the new model has grown by 2.4-inches and overall length has grown by 4.7-inches compared to the old model. The longer overhangs mean the approach and departure angles are slightly degraded for the new 4Runner at 32 and 24 degrees respectively compared to 33 and 26 degrees for the four-wheel-drive fifth-gen. However, the nearly 20-inch shorter wheelbase compared to the Tacoma should give the 4Runner a big advantage over the pickup in breakover angle.
Like Toyota’s other off-roaders and most competitors launched in recent years, the 4Runner gets a Multi-Terrain Select system that allows the driver to choose modes that are optimized for the type of surfaces being driven on. The modes which include Mud, Dirt and Sand adjust parameters like the slip thresholds for traction control and work in both 4WD-high and low ranges. The Crawl control manages speed on rough surfaces so the driver can focus on steering around obstacles on the trail.
The design shares a strong family resemblance to the new Tacoma but also has callbacks to early generations. The rear top may not be removable anymore, but the rear quarter windows do wrap into the roof again. The tailgate glass can also be lowered into the gate as has been the case in prior generations allowing for longer objects like surfboards to hang out the back.
The interior also shares a lot with the new Tacoma including the choice of a standard 8-inch infotainment screen or the optional 14-inch display. Both use Toyota’s latest infotainment software which is much improved from prior generations. Wireless support is included for both Apple Carplay and Android Auto and a Qi wireless charging pad is also available in addition to the standard USB-C ports. Toyota’s Safety Sense 3.0 driver assist package comes standard as it does on all other newly designed models. This includes blindspot monitoring, radar adaptive cruise control, lane keeping assist, road sign recognition, and proactive driving assist.
In addition to all of the usual trims found on Toyota trucks and SUVs, the 4Runner also offers the new Trailhunter trim. The Trailhunter includes ARB's Old Man Emu (OME) 2.5-inch forged shocks with remote reservoirs on the rear axle and a custom ARB roof rack. 33-inch Toyo Open Country all-terrain tires provide the grip along with two-inches of added front ground clearance and 1.5-inches in the rear.
Rock rails and high strength steel skid plates come standard on the Trailhunter along with a bronze grille and integrated 20-inch LED light bar. Toyota has also built in a 2400W inverter to power gear during overlanding adventures.
The 2025 4Runner goes on sale in fall 2024.
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 11:06 AM #2
taxzz's Avatar
taxzz taxzz is offline
taxzz will become famous soon enough taxzz will become famous soon enough
taxzz's Avatar
i'm sure this will sell really well, but i'm not in love with the styling or the fact that it got bigger. how can this compete in the same space as the new LC?
2007 Limited V8 | Apache AX2 and Dobinson 3" lift
2004 Limited V8 | Dobinson IMS Long Travel 3″ lift w/ SPC UCAs | Yoko 35x12.5/17 | Rear Locker | Front LSD !!!!FOR SALE!!!!
2004 SR5 V6 | Sold
taxzz is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 11:12 AM #3
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Screen captures curtesy of yours truly. Sorry for the hundreds of photos, I wanted to have overlap for continuity. Link to album
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 11:58 AM #4
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
Thanks for sharing this.
I agree, it’ll surely sell well, but it’s definitely not for me. Makes me even more glad to have scored a 2022.
With the shared styling and platform, I imagine this will be built in Mexico. That alone is a deal breaker for me with any vehicle.
hoppyjr is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 11:59 AM #5
schwein schwein is offline
schwein is on a distinguished road
What are they thinking with a Sequoia and 4Runner being dangerously close to each other in size and style...
2003 - 4Runner Limited V8 (Sold)
2014 - 4Runner Limited V6
2019 - GX460 Premium V8
schwein is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 12:39 PM #6
Blackwatch's Avatar
Blackwatch Blackwatch is offline
Blackwatch has a spectacular aura about Blackwatch has a spectacular aura about
Blackwatch's Avatar
Well unless it grows on me which I doubt I can’t see myself ever buying this generation.
4.7 inches longer, the wheelbase has gone outside of Toyotas sweet spot for some reason. Most likely a couple of inches wider, overall too big for a 4Runner. I really like the looks of the LC250 but this looks like a 4th gen that AI modernized. Too futuristic looking for me.
Very disappointed
2022 OR lunar rock
Blackwatch is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 12:50 PM #7
TexasFunRunner's Avatar
TexasFunRunner TexasFunRunner is offline
TexasFunRunner is a jewel in the rough TexasFunRunner is a jewel in the rough TexasFunRunner is a jewel in the rough
Here is the...
Official Reveal Thread 2025 6th gen 4Runner
TexasFunRunner is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 01:03 PM #8
Very disappointed
Agreed. If I were buying one or the other, it would be the new LC.
Gen 5 T4R > LC250 > Gen 6 T4R
Old 04-09-2024, 01:14 PM #9
crash404 crash404 is offline
crash404 is on a distinguished road
Between the Sequoia, 4Runner, and the Land Cruiser (not to mention the GX) it feels like Toyota is crowding the market with similar-ish vehicles.
The exterior looks better than I was expecting, but I was shocked to see that they increased the dimensions. The interior is what I was expecting...except for what appears to be some atrocious leg room in the second row. I can't imagine having my two teenagers sit back there for an extended amount of time.
Oh well...makes me even happier I picked up my TRD Pro last month.
crash404 is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 01:37 PM #10
Quentin Quentin is offline
Quentin will become famous soon enough Quentin will become famous soon enough
The front seats are pushed all the way back. Look at where the console stops... like 6" ahead of the seatback. The legroom will very likely be comparable to the current model.
2023 4Runner TRD Pro, 2023 GR Corolla
Quentin is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 04:09 PM #11
So Many Roads's Avatar
So Many Roads So Many Roads is offline
So Many Roads is on a distinguished road
Goodness this thing is ugly. Looks like a cross between a 4th gen and a 2nd gen.
Been waiting (forever) for the sixth gen but doubtful I would buy one of these.
'99 SR5, 5 spd, Bilstein 4600, elocker mod, TBU
So Many Roads is offline   Reply With QuoteReply With Quote
Old 04-10-2024, 12:53 AM #12
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Thanks for the photos of the new 6th gen!
Size is a certainly a surprise however I think the overall styling beats out LC and GX and I really like the looks. I like the new beefier stance and most important for me, it still looks like a 4runner! Lots more masculine than 5th gen -not sure if that is good or bad.
6th gen could have been horrible and embarrassing to all the prior T4R owners and I am so glad it looks this good. It will be interesting to follow on the forum how the quality holds up and wishing the 6th gen the best!
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 04-10-2024, 02:14 AM #13
SocalRunner15 SocalRunner15 is offline
SocalRunner15 is on a distinguished road
Not a fan at all of the styling. It looks super generic...almost like a 4th gen model.
SocalRunner15 is offline   Reply With QuoteReply With Quote
Old 04-25-2024, 01:33 PM #14
BTO's Avatar
BTO BTO is offline
BTO is on a distinguished road
BTO BTO is offline
BTO's Avatar
I think overall the appearance is an improvement to the too boxy 5th gen. It looks much more aerodynamic. The only thing I don't like is the black fender flares. Looks like the Limited comes with color keyed fender flares. That looks much nicer. I can see the other trims going that way in later model years.
BTO is offline   Reply With QuoteReply With Quote
Old 04-25-2024, 02:17 PM #15
Blackwatch's Avatar
Blackwatch's Avatar
I like the boxy style of Toyota BOF SUVs. If I can't have a land cruiser I want the 4R to resemble one. One narrow trails and tight Central American streets/roads you don't want a wide vehicle. The 70 series is perfection for these places.
2022 OR lunar rock
4runner , rear , tacoma , toyota , toyota’s
HTML code is Off
New BFG A/T KO 2 soon to be released! 99 sr5 highlander Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-19-2013 02:07 AM
Jeeps on Forbes 2011 Worst Cars list TheSentinel General Discussions 14 05-04-2011 03:00 PM
T4R Makes Forbes Best CPO List My1stT4R 4th Gen T4Rs 0 02-28-2008 10:59 PM
Cars That Best Retain Their Value... (Forbes) charlier180 4th Gen T4Rs 2 11-13-2006 11:18 PM
Forbes' Worst Koz Off Topic 4 07-22-2006 01:45 PM
