The rear wiper and defroster probably just aren't working because they need to learn where the "up" position is for the rear window glass -- it needs to be "re-taught" every time the battery is disconnected. Just roll the rear window down a little bit, then roll it back up all the way, and KEEP HOLDING DOWN the up button for about 2 extra seconds after it's all the way closed. This teaches it where the fully-closed position is, and those features will be enabled again.
As for the dome light, have you tried replacing the bulb? Hopefully it's that simple.
04 V8 SE 4WD
