Originally Posted by sp8ball
If I was interested in this, should I do fog lights or driving lights?
PIAA Lights - PIAA Bulbs, PIAA Headlight, PIAA Fog Lights & Off Road Lights
I was looking at the 520s.
Attachment 43474
Which color? I was thinking amber fog lights, but what if the light doesn't match my jet yellow Putco bulbs? Would it be safer/easier to just make them driving lights?
And why do they look purple and yellow?
The "protective cage" would be black, naturally. I'd be placing them in the lower grille area in an attempt to look awesome.
The PIAA 520's are way to big to fit in the lower grill . The lens alone is 6 1/4 " and with the lower mount and grill on is close to 8" . That's what she said!
The 510's are as big a round as you can fit in the lower grill and they have several reflector types available. If your putting yellow fog bulbs in the oem fogs then you shouldn't need another set of fogs unless your moving to San Fran. I've only used my PIAA's twice for actual foggy conditions in over a year.
Any lights other the fog lights(driving lights) up front should be treated as high beams and can be wired to be triggered by your high beam switch.
Here's PIAA's website and they have all the info you should ever need on different lights .....
PIAA
