Originally Posted by truckmike26
In these 5011 tests, what size particles (in microns) or groups of particle sizes were there?
From the link:
"Capacity and Efficiency:
The Capacity and Efficiency test report presents the test results of feeding an initially clean filter with PTI Course Test Dust (dirt) at a constant rate and airflow. The course test dust has a specific distribution of particle sizes ranging from less than 2.5 microns to greater than 80 microns (see table below). Every filter is initially tested at 350 CFM and the Initial Restriction or differential pressure across the filter is recorded in IN-H20 (Inches of Water). The filter is then tested by feeding test dust at a nominal rate of 9.8 grams per minute with a constant airflow of 350 CFM. The test is continued until the flow restriction exceeds the Initial Restriction + 10 IN-H20. At this point the test is terminated and the amount dust passed through the filter - Accumulative Gain - is measured. Dirt passing through the filter is captured in the Test Station’s Post Filter. The exact amount of dirt passed is determined by measuring the before and after weight of the Post Filter. Similarly, the amount of dirt retained by the Filter under test - Accumulative Capacity – is measured by taking the difference between the before and after weights of the Filter. From these results the overall % Efficiency of the filter is calculated. This test also indicates how long a Filter will last before replacement is required (or cleaning for reusable filters)."
