View Single Post
Old 08-21-2011, 04:43 PM
jonwilly2 jonwilly2 is offline
jonwilly2 is on a distinguished road
Originally Posted by Rockdawg84 View Post
I will look and see if I can find the length but remember you also need to match Piston Pin size and crank size as well as rod thickness. What motor are you looking at for the new rods to come from?
The Nissan VQ35DE it has the same pin end size of 22 mm and the same crank size of 2.165 inches. The VQ35DE is a 3.5l v6 it is 120cc bigger then the 5vz the boar is 95.5mm and the stroke is 81.4mm The 5vz has a boar of 93.5mm and a stroke of 82mm that is damn close. That engine can be found in the following.
2001–2004 Nissan Pathfinder (240 hp)
2001–2004 Infiniti QX4 (240 hp)
2002–2004 Infiniti I35 (255 hp)
2002–present Nissan Altima (240 to 270 hp)
2002–present Nissan Maxima (255 to 290 hp)
2003–2006 Nissan 350Z (287 to 300 hp)
2003–2004 Infiniti G35 (260 to 280 hp) all models
2005–2006 Infiniti G35 (280 hp) automatic transmission models
2005–2007 Infiniti G35 (298 hp) manual transmission models
2003–2008 Infiniti FX35 (275 hp)
2003–present Nissan Murano (Z50) (245 to 265 hp)
2004–present Nissan Quest (235 to 260 hp)
2006–2008 Infiniti M35 (275 hp)
That is a lot of engines and a lot of ricers upgrading to stronger parts so used ones should show up sooner or later. Eagle has H beam connecting rods for less then $500 for a set. LC engineering $1200 for their crossbeam connecting rods and $400 for the forged ones for the extra $50 to $75 I would go with the stronger H Beam rods from Eagle for the Nissan.
I know putting Nissan parts in a Toyota may sound like a sin but for the price of the stock ones that could be gotten used for cheap is a grate deal of awesome.
2000 4Runner SR5, Cold air intake, Auto, 2wd, 4.88, big dent
1995 4Runner SR5, E-locker, ATs, 5 speed 4x4
jonwilly2 is offline   Reply With QuoteReply With Quote
