Uh... Moving on just because of a axle seal leak?! That would be stupid. They are one of the most common issues with these trucks, and are extremely easy to replace. The seal from Toyota is ~$20 and takes maybe 30 minutes to swap out.
Yeah you're supposed to change the brake shoes as well if they are saturated with diff fluid, but I often clean them good and don't have problems.
If the brake fluid is not low then you can pretty much assume its an axle seal.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
